exhaust leak issue
Old Apr 18, 2008 | 03:18 PM
Ironxcross's Avatar
Default exhaust leak issue
so one of my friends decided to be an asshat and sawzall my exhaust behind the collectors on both sides of the y-pipe. for a while i had bandclamps, and still heard a leak. got the cuts welded today.. and i STILL hear a leak. the weld is good... so is it leaking from somewhere else? the header bolts are tight.. im sort of at a loss here.
Old Apr 18, 2008 | 03:26 PM
the_merv's Avatar
Look around for soot..
Bad_tx_Z28's Avatar
well...the only thing i could tell you is cold start the car and run your hand next to the pipe and see if you feel some leaks...
Old Apr 18, 2008 | 04:10 PM
Ironxcross's Avatar
thats the problem, i dont feel ANYTHING. i hear a leak though.
Old Apr 18, 2008 | 04:13 PM
Purple95Z28's Avatar
I know someone who had a ticking exhaust leak she couldn't track down after weeks and it turned out to be the egr tube was leaking because it had gotten bent up during header install..
Old Apr 18, 2008 | 06:34 PM
Ironxcross's Avatar
i looked at everything again. everything is tight and good. my car just doesn't make any sense. thats all!
Old Apr 18, 2008 | 06:44 PM
the_merv's Avatar
Front or Back of the Car?
Old Apr 18, 2008 | 09:20 PM
Ironxcross's Avatar
front drivers side, starting at the engine til about the middle of the door.
Old Apr 18, 2008 | 09:57 PM
the_merv's Avatar
How loud is it and how consistant is it?
Old Apr 18, 2008 | 10:21 PM
Ironxcross's Avatar
gets louder under load, sounds like an air escaping sound. checked the header gaskets again, still good. im going to tighten them more. maybe it'll help.
Old Apr 19, 2008 | 03:19 PM
Ironxcross's Avatar
i checked the headers and drove it around. maybe it blew out of gasket. im so tired of screwing wtih this thing so it doesnt leak.
Old Apr 19, 2008 | 07:05 PM
Bad_tx_Z28's Avatar
hmm...i have the same prob...i found out that my noise was valvetrain...for some reason the rockers on the right bank are extremley loud when warm...cant figure it out
Old Apr 19, 2008 | 08:38 PM
formula1785's Avatar
i have the same problem with my stock manifolds..i hear the sound but cant seem to find the leak and its getting to me...most of the noise is the hydraulic
lifters....
Old Apr 19, 2008 | 09:31 PM
Ironxcross's Avatar
are aftermarket rockers more noisy and causing this sound?
Old Apr 19, 2008 | 09:33 PM
Revelation Z28's Avatar
roller rockers will make alot of ticking
Old Apr 19, 2008 | 09:35 PM
Ironxcross's Avatar
would this ticking be worse under load?
Old Apr 19, 2008 | 09:37 PM
i dont know about that, but ive heard an LT1 with 1.6 RRs on idle in person and it ticked like a bad header gasket.
Old Apr 19, 2008 | 09:39 PM
Ironxcross's Avatar
damn it. this is such a weird sound and it doesnt make sense for it to be a bad header gasket.
Old Apr 19, 2008 | 09:56 PM
open the hood and have someone start the car in an enclosed space (closed garage) and keep your head above each header and see if you smell the raw catless smell of the exhaust before the tailpipes fill it. thatll be the easiest way of finding a header gasket leak.
Old Apr 19, 2008 | 10:03 PM
StealthFormula's Avatar
I have the same problem and its freaken annoying. I checked everything and no idea, it sounds so much like a little exhaust leak under load but I cant trace it. I'm pulling the LT's out for the heads so Im going to make certain that everything goes together perfect and then see what happens. My 1.6's are noisy at idle but I cant imagine they would sound like a leak under load.
