lt1 backfireing!!!!!!!!!!!!!!!! HELP!!!!!!!!!
Old Apr 20, 2008 | 03:56 PM
SJblackLT-1's Avatar
Default lt1 backfireing!!!!!!!!!!!!!!!! HELP!!!!!!!!!
having some backfiring problems with my SS. i took off the wires and checked spark. 2 out of the 8 have low spark the other 6 bout the same. could that mean need a new opti or could it be i have 2 defective wires. have msd wires and 1 1/2 year old msd opti. i currently have ngk spark plugs but was wondering if the ac delcos are better or bout the same?? any help would be great thanx!
Old Apr 20, 2008 | 05:22 PM
NorthernZ's Avatar
Is it happening all the time or at wide open?
Old Apr 20, 2008 | 06:45 PM
it has a constant misfire. checked all my plugs and wires again an the all seem to be good. i put a obd2 to it and it doesnt tell me wat cylinder misfireing it gives me code p0300 which says engine misfire. im guessing it gana end up being my opti.
Old Apr 20, 2008 | 07:07 PM
NorthernZ's Avatar
I had problems in the high rpm range at wot and it was the coil. I cleaned the coil contact and changed the coil wire.
Our problems don't sound the same at all though, sorry I can't be more help. I just finished talkin on a thread about stock/accel/msd optis. You sould give it a read if infact you do end up changing your distributor. Good luck
Old Apr 20, 2008 | 07:13 PM
robsquikz28's Avatar
change out ur cap/rotor but first check and make sure there are no burnt wires i would def. say its ur opti
Old Apr 20, 2008 | 07:45 PM
SS#502's Avatar
Start her up at night and pop the hood. In the dark, if you have a crack in your cap you might be able to see some fireworks below your waterpump. My coil wire a while back was grounding out to the MAF bracket that it was rubbing on.
Old Apr 20, 2008 | 11:44 PM
good lookin out. thanx!
Old Apr 21, 2008 | 11:11 AM
krayzie7th's Avatar
it can be your coil, i would check the coil and replace it first before i think of buying a new opti.
Old Apr 21, 2008 | 10:49 PM
coo thanx ill try dat as well
