160 stat vs 190?? tune difference? please read
mentioned, when it fails, the valve snaps in the OPEN position, allowing coolant
to continue to flow. But be forewarned - in this state, it would be the same as
running with no thermostat and you would most likely see a high-engine-temp
condition, since the water never has a chance to absorb the engine's heat.
http://www.motoradusa.com/products/f...rmo/index.html
A MotorRad 160* part # is 307-160; a 180* is 307-180, a 195* is 307-195,
and the Fail Safe: 160* is 7307-160, 180* is 7307-180, and 195* is 7307-195
