possible LT1 race in August or early Sept
#41
possible LTx showdown rules
What do you guys think of these they are just about the same as the LTx shutout with slight changes which I hope ma bring in some extra cars.
SHOWDOWN rules
Classes, Rules & Payouts
Classes and rules are subject to change.
Payouts are estimates depending on event participation.
LTX Outlaw
• Run what you brung HEADS UP format
• Limited to quickest 16 qualifiers
Must have LT1 based engine. If heads do not retain factory 23° valve angle, a 150 lb. weight penalty will be enforced. Converted intakes, sheet metal, or stock intakes allowed. Multiple power adders allowed. 10.5 tire max (W’s limited to 29.5). Drag radials permitted any size. Stock style suspension preferred. If you have a 4-link or similar setup a 150 lb weight penalty will be enforced. Mini tubbing allowed. Wheelie bars allowed. No back half cars. Mufflers are an option. Any carburetor allowed. Any EFI system allowed. Any OEM style transmission allowed. If Non-OEM style transmission, a 100lb weight penalty will be enforced. Lexan permitted. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Weight 2800 nitrous 3300 forced induction.
Class Sponsors:
Estimated payout: TBD by participation
LTX Drag radial (Power Adder)
• Limited to quickest 32 qualifiers
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Converted intakes, sheet metal, or stock intakes allowed. Single power adders only. Nitrous must be single stage. Supercharger FIA,YSI max. Turbo limited to 81mm. Twin turbo setups must send details of setup to the organizer for decision. Drag radials permitted any size. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any EFI system allowed. Any one piece carb allowed. Any OEM style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Nitrous only cars get 300 lb weight break off the minimum. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Heads up N/A (Naturally Aspirated)
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Converted intakes, sheet metal, or stock intakes allowed. No power adders allowed! 10.5 X 29.5 tire max. Drag radials permitted. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any carburetor allowed. Any EFI system allowed. Any OEM style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Heads up 6-speed
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Single stage power adders allowed. Aftermarket intakes allowed with a 100lb weight penalty. Stock PCM only (Aftermarket EFI 50lb weight penalty). 10.5 X 29.5 tire max . Drag radials permitted any size. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any carburetor allowed. Any OEM manual style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Extreme Street
Must have LT1 based engine. Heads must retain the factory 23° valve angle (no converted SBC heads). Only stock/stock style ported intakes allowed (welded intakes not permitted). Single stage power adders allowed. Stock PCM only (no aftermarket EFI). Opti-spark distributors only no rear mount allowed. Coil per plug allowed. DOT tire only. Maximum size 28" X 10.5" (actual tread with). Only exception will be 315/35-17 drag radials, 325/50R15 allowed, dr limited to 28”. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any OEM transmission allowed. Must have factory glass (no Lexan…etc). Must have working lights, wipers, and horn. Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3400 lbs.
Class Sponsors:
LTX Bracket - 12.49 & Faster
• No limit in entries
Must have LT1 based engine. Transbrakes allowed. NO electronics ( delay boxes, throttle stops..etc). Car and driver must meet NHRA/IHRA certification requirements for the times the car is running.
Class Sponsors:
LTX Bracket - 12.50 & Slower
Must have LT1 based engine. NO electronics (transbrakes, delay boxes, throttle stops..etc). Car and driver must meet NHRA/IHRA certification requirements for the times the car is running.
Class Sponsors:
SHOWDOWN rules
LTX Outlaw
Class Sponsors:
Class Sponsors:
Class Sponsors:
Class Sponsors:
LTX Extreme Street
Class Sponsors:
Class Sponsors:
Class Sponsors:
#47
Since we just missed the LTx shootout we might make this one.
One request, put the head rules / weight penalty and trans rules / weight penalty from outlaw in power adder and Heads up N/A also, hell even up the weights if you want, just wanna compete in something other than outlaw for a full interior 3700lb street car...
#48
#49
That's what everyone thinks. On a 4.030" bore they flowed 339cfm. There are guys out there with 23* that are close to that. That's why it's not that much of an advantage on the small bore. I just can't seem to convince anyone of that. Besides dragging around 600+ extra pounds kinda negates that. I appreciate the thought though and anything you'd be willing to do is helpful.
#50
Heres a link to the forum. http://ltxshowdown.forummotion.com/index.htm
Stop by and register
I'll have the rules up on a web sight before long
#51
Oh boy, I was all excited about a date set and I ran in told the new wife, " Date is set, Sept. 7th, LT1 Shootout at Cordova, SWEET." She replies, " On our 1st anniversary". Oh yea, I knew that was a special day. We will bring both our LT1 cars so you can race too honey.
#60
