miss-fire and stall out, at specific RPM range
ok guys, i just got this car. It will not drive past 3k RPMS.
it will idle, you can rev it past 3k with no problems.
as soon as its moving ( load ) the minute you hit 3000 RPMs the car gets fuel cut and if you put the clutch in it dies! we changed the MAF, and now it just misfires bad, but wont stall out.
will a crack in the intake tube right in front of the Throttle body cause this?
or is this going to be opti-related?
tried searching in vain, any help would be greatly appreciated.
its right at the Throttle body. and the car backfires alot right now.
but still accels normal untill right at 3000rpms then misfires and wants to die.
