fuel pump bucket
Old Apr 27, 2008 | 11:55 PM
fordeater's Avatar
Default fuel pump bucket
do any of you guys by chance have the GM part number for the fuel pump bucket out of the f-cars.
Old Apr 28, 2008 | 01:40 AM
ss.slp.ls1's Avatar
What happened to the old one? If it was cracked or anything, I would just epoxy it. You have to pry open the cap and epoxy it back on when swaping in a new pump anyway. Technically, if you made sure never to run below a quarter tank, you don't need one.
Old Apr 28, 2008 | 10:26 AM
fordeater's Avatar
I cracked the top of it, not sure if I need a new one or can re-use this one. I cracked it where the whole for the pump plug in connector goes.
Old Apr 28, 2008 | 10:39 AM
Vicious95Z28's Avatar
I doubt you'll be able to get it from GM unless you buy the entire module.
Old Apr 28, 2008 | 11:22 AM
ss.slp.ls1's Avatar
Get one of those two part plastic epoxy tubes, the one where you have to mix it together, and apply generous amounts and let if set for the appropriate time and it should be good as new. Like I said, you have to epoxy the bucket closed with the new pump inside anyway, using more epoxy to seal a crack in the lid won't change anything.
