would this work
Old Apr 28, 2008 | 11:25 AM
95Banshee's Avatar
Default would this work
i know most of you have jegs if you look at the inside view of the warlock racing muffler. do you think it would work as a cross flow muffler. just look at it and i hope you understand how it might work because i don't know how to explain it.
Old Apr 28, 2008 | 11:46 AM
IronOutlaw's Avatar
i think it would work. it would just be really loud out that one tailpipe. with a little bit of modifying it could be like a borla catback.
Old Apr 28, 2008 | 11:49 AM
95Banshee's Avatar
if you went in backwards and it exited through the caped hole and the hole it is ment to enter.
Old Apr 28, 2008 | 12:37 PM
IronOutlaw's Avatar
actually that seems like a pretty good idea. im just not sure how those mufflers sound but i think it would work.
Old Apr 28, 2008 | 01:03 PM
green95vert's Avatar
I've heard they sound like flowmaster, just a slightly different rumble/tone. Sounds like a great idea, go for it.
Old Apr 28, 2008 | 03:11 PM
Formula350's Avatar
Try it up, and post a vid of the results (Not just idle, but how it sounds under a load)
Old Apr 28, 2008 | 08:17 PM
95Banshee's Avatar
on the pipes that muffle it are the holes holes or directional slits because if they are directional they might not work well and where it enters the pipe and splits i donyt know if that would disrupt flow. i was going to get a TSP rumbler but now i might think about this.
Old Apr 28, 2008 | 09:09 PM
IronOutlaw's Avatar
i think it is a turbo style muffler from what i understand, so it should flow just as well foward and backward. if it is a chambered muffler it would not flow good.
Old Apr 28, 2008 | 09:28 PM
95Banshee's Avatar
i would try that but i going for vary loud and i don't think that would be as loud as i would like it. if anyoun else trys this out post a vid so we can hear it honestly that muffler is not that much and it could turn out that it works excelent and make a second use for it and just add one more crlss flow to the f-body list.
