cam swap grocery list
Old Apr 29, 2008 | 08:34 AM
speedracer2536's Avatar
Default cam swap grocery list
ok so i am in the process of collectiong the parts for my cam swap. so far i have
cam
springs
pushrods
guidplates
arp rockerstuds
1.6 roller rockers
new opti
new wp
what all is needed to complete the build up? gaskets and etc i need to know everything that i need to finish it up. i know a tune is needed and i have that in order as well.
Old Apr 29, 2008 | 08:42 AM
Pampered-Z's Avatar
http://www.97transam.com/97ta-cam.php
Old Apr 29, 2008 | 10:18 AM
BALLSS's Avatar
valve stem seals
get hardened guide plates and push rods
Old Apr 29, 2008 | 10:30 AM
BOLO's Avatar
Kills two birds with one stone and have the heads ported and install LS1 valves. Just my 2 cents.
Old Apr 29, 2008 | 10:37 AM
StealthFormula's Avatar
Post up the part #'s that way we can see if everything will work together. Dont forget locks, retainers, and shims for the springs. Also a new GM timing chain.
As far as gaskets you will need:
front timing cover gasket, opti-spark seal, crank seal, water pump drive seal, egr gaskets, throttle body gasket, intake manifold gaskets, valve cover gaskets, and water pump gaskets
