Can i remove the air silenoid?
Old Apr 29, 2008 | 02:16 PM
camarostripes96's Avatar
From: Academy,Tx (home of temple/academy Drag Strip)
Default Can i remove the air silenoid?
Ok I have a 96 trans am LT1 and I did an egr/air delete,so can I unplug the air silenoid and take the silenid and its wire and plug off my car?
Old Apr 29, 2008 | 09:28 PM
Formula350's Avatar
The EGR solenoid? Or...?
Just leave the EGR solenoid and cap it off, but leave it plugged in.
Old Apr 29, 2008 | 10:52 PM
the air silenoid, the one the air pump is plugged up to, or the one it was plugged up to
Old Apr 29, 2008 | 11:16 PM
Formula350's Avatar
You just remove the AIR pump and then that's all, leave the fuse plugged in and that's it.
Old Apr 30, 2008 | 08:14 AM
What fuse u talking about?
Old Apr 30, 2008 | 08:30 AM
HoLLo's Avatar
The fuse labeled AIR Pump
Old Apr 30, 2008 | 09:09 AM
Formula350's Avatar
HoLLo! Quick, don't post anything else!
Old Apr 30, 2008 | 09:56 AM
Ok I got race style headers ok, I removed the egr and put block off plates on the mack of intake on both spots! I left the egr sileniod and left the clip in it and pluuged the intake with a vacumm cap! Then I removed the air pump and all rubber hoses and cut the metal pipe that goes around the bottom of the motor! Ok the is some wires that come from the driver side and has a male plug on it, that plugs into a female plug that goes to a silenoid on the front of the engine by the throttle body, well that male and female plug are plugged in one another and Clipped to the bottom of the air pump and 2 wires are coming off the female plug and going into the air pump (a red wire and black wire)!! I cut both of the wired and removed the air pump and left the plugs plugged together!! So what else do I need to do? Can I remove the silenoid those go to and remove the female end of the plug? .... If that confuses u just tell me what I need to take off to do an aire delete!! Where is that fuse located at? Yall go me confused
Old Apr 30, 2008 | 10:00 AM
Slowmaro95Z28's Avatar
I was kinda wondering something like this too. My AIR and egr are tuned out so can I cap off the intake and delete my egr solenoid?
Old Apr 30, 2008 | 11:51 AM
Formula350's Avatar
My ECM isn't as "smart" as 94+ PCM is, but I tuned everything out I could find. I removed my air and unplugged my EGR, but as soon as I removed the EGR solenoid, check engine popped right on when started up. So I just unhooked all the vacuum lines and then capped everything off (even the EGR I think heh).
Even if you aren't going to use it, you should never cut anything, just unplug it. Cutting it doesn't "trick" the computer into thinking somethings there. Cutting = unplugging to the computer. Cutting is always a bad idea in case you ever sell it and the new owner needs the air pump for emissions checks.
Unless something has changed, there is no AIR pump solenoid that I saw when I removed mine, so I basically told you all you need to do.
Old Apr 30, 2008 | 11:58 AM
infinitebird's Avatar
yes you can remove it if you want. if you removed the air pump its not going to do anything.
Old Apr 30, 2008 | 12:20 PM
ok well the air pump has 2 wires coming from the plug that goes to the silenoid....can i remove that whole plug ? what about the silenoid
Old May 1, 2008 | 12:11 AM
ok here is what i am talking about, the wires i am holding are the female wire that goes to this little silenoid on top of the motor, with the little gray cap on it, and the female plugs into the male plug that goes to the pcm i guess!! so can i take this off?
Old May 1, 2008 | 12:16 AM
ok here it is its the little silenoid with the grey cap and the wires that go to it is the one with electric tape on it, thats the one the air pump was spliced too, so can i take this thing off?
Old May 1, 2008 | 12:45 AM
Formula350's Avatar
I guess I didn't follow my wires, I just unplugged the AIR pump and left it at that.
Old May 1, 2008 | 01:05 AM
HoLLo's Avatar
Old May 1, 2008 | 02:16 AM
Formula350's Avatar
Originally Posted by HoLLo
Post count was 666. 667 now, YOU RUINED IT!
Old May 1, 2008 | 07:25 AM
Well I can't just unplug my air pump it has 2 wires coming off the air pump and those wired are goin to a female plug that wires goes to some silenoid on the front of the engine as u can see, well that female plug plugs into a male plug wirth wires going into a big wired loom (I guess to the pcm) but there is a little vacumm silenoid that connects to rhe air pump and has vacumm lines goin to the intake!! Does anyone know what I am talking about at all?
Old May 1, 2008 | 08:07 AM
moserman's Avatar
i do, i was told that you need to keep your solenoid plugged in unless you have it tuned out because it will throw an engine code because the sensor wouldnt be plugged in, but thats about all i could make out of it. ill get a better answer later today.
Old May 1, 2008 | 09:35 AM
Ok mine is a 96... Explain to me what u mean u unplugs the air pump? On mine there is no plugs no there is 2 wire looms plugged together that are mounted on the air pump and there is 2 wires goin in to air pump , but u cannt just unplug the 2 wired to the air pump cause there is no plug, I had to cut the wires! Do yall get what I am saying?
