breathers what do they do
yes as I mentioned its not much air, and the PCM should be able to compensate for it. But in my case mine didn't. Mine would always want to die and you could see the BLMS were off. I put the stock hose back on and removed the breather and never had a single issue.
I did not know about it... But I did it on my own thinking I was sucking oil in to my IM through there after pulling the TB and seeing oil in the IM.
I just used one of those chrome universal PCV setups so it could still be hooked to vaccum on the TB incase in was important.
However, when crankcase pressures build-up and the PVC system vaccum can't keep-up, hot oil gases are pushed back through the fresh-air tube (reverse flow) and into the throttle body.
WD
That is the "fresh-air inlet" for the PVC system. By design, filtered fresh-air is pulled through the throttle body an into the passenger's side valve cover, then pulled back-out of the crankcase by the PCV valve.
body and into the passenger's side valve cover, then pulled back-out of the
crankcase by the PCV valve."
Yes, I read the "however" part, but I *think* that is mentioned because it's
a side-effect, not how it's designed. It's a given, since there is no valve.
I mean, really, would a Chevy engineer design an engine component to not
work under a worse-case condition?
WD
WD
http://www.partsamerica.com/productd...tNumber=B23165
#33
Perhaps a better way to word it would be unmetered air. It is air entering the engine after the MAF sensor (as with a vacuum leak), hence the PCM does not account for it and this creates a lean condition. The O2 sensors will see this and the PCM will try to compensate, but it will essentially be running around in circles. However this would not be a problem on an engine operating in speed density mode, such as '93 LT1s or any car that has been tuned to speed density.
I use the term vacuum leak to describe any opening that lets unmetered air into the into the intake manifold, is that not correct?
#35
Village Troll
I would prefer calling it an unmetered air leak rather than a vacuum leak.
Several years ago before we knew any better a friend of mine and I were running breathers when it was the "cool" thing to do and noticed no performance difference.
#36
OMG, my LTX race engine is not "green friendly." But, I'm making a lot of HP and getting down the track really fast, so what the hell. Sorry about that Al.
When you're running low-tension rings, you'll need additionaly crankcase breathers, as the factory PCV system can't keep-up at high RPM.
WD
WD
#37
The way I read it is, "by design, filtered fresh-air is pulled through the throttle
the FSM describes and illustrates the two way function of that fresh air hose
#39
1) Don't ever run a breather AND a PVC... if the PVC valve sticks open you'll have a wassive vacume leak.
2) PVC serves a similar function as a breather without spewing oil-mist into your hood liner or on your engine.
If you have a LOT of blow-by (ie. rings gapped for N2O, boosted applications, excessive cylinder wear, low-tension rings, etc...) and the PVC just isn't cutting it anymore a breather can help you from blowing the dipstick out, but your best bet is a vacumn pump or a dry0sump oil system. Neither is cheap.
Breathers are just an easy/dirty fix to popping dip sticks or constantly-fouling PVC valves.
#40
I'm seriously tossing around a few options, but a dry-sump oiling system is just too much cash.
