This is why you weld the pickup tube...PICS
DAMN Kyle!!
You should have known Mr Know it all would have some thing to say, Ignore him the rest of us do
BTW I like to weld a Tab to the pick-up and attatch it under one of the cover bolts
Go ahead and change all the bearings now man before you do any more damage
Good luck man!
That one looks like it feel off with the drive shaft
Good luck man!
I think I've got a new set of bearings already.
I think Moe is talking about the Canton pick-up, it is gold in color. Same as the one I'm running, I have the Moroso blue printed w/ hex-key drive pump, and all I had to do was take out one of the oil pump body bolts and install the pick up tube and re-install the bolt thru the pick-up tube bracket... = stay put.
That be da one.....
