LT1 swap
Old May 5, 2008 | 01:22 PM
davbroncos's Avatar
Default LT1 swap
hey guys i was juss lookin at a cheap 96 vette LT1 with low low miles and got an offer i couldnt refuse
so im going to drop it in my car which is a 99 v6 camaro
i was wondering if i would need to swap out the whole cooling system i have now to satisfy the reverse flow cooling of the lt1, and what would be some other stuff i HAVE to switch out, such as the opti..
thanks guys, David
Old May 5, 2008 | 01:27 PM
davbroncos's Avatar
Default some pics for the curious ones...
its pretty much just a crate engine with the wiring
Old May 5, 2008 | 10:36 PM
LT1's Avatar
LT1
Is your car auto or 5 speed? youll also need LT1 fuel pump.
Old May 6, 2008 | 01:37 PM
davbroncos's Avatar
the V6 is an A4
would i be able to use the same 4L60E tranny for the LT1?
Old May 9, 2008 | 05:59 PM
LT1's Avatar
LT1
yeah, but youll need a different stall converter, it also has little different valve body setup but you can still use it.
Use A4 LT1 PCM and harness too.
Old May 9, 2008 | 07:13 PM
Formula350's Avatar
I don't think the V6 bellhousing is compatible. You'll need the fuel pump, wiring, transmission, and PCM.
Also, weren't all 96s Grand Sports, and all Grand Sports LT4s? Bcause that sure isn't an LT4...
Old May 9, 2008 | 07:33 PM
Schweet97Z's Avatar
I dont think its out of a vette....look at where the altenator would sit.
Old May 9, 2008 | 10:02 PM
Formula350's Avatar
From what I can remember about my friend's 94 Vette, his is on the same side as ours, but the power steering is up on the upper drivers side. But it has been awhile since I've looked at it.
There's also no knock sensor >_>
Old May 9, 2008 | 11:08 PM
the_merv's Avatar
Veteran: Air Force
That came from a F-body.. it's got the F-body Alt. Bracket, and the F-body Oil Fill Tube. That and you would have to cut the Harness out of a Corvette..this one here has all the F-body Connections.
A V6 4L60E will not bolt up to a V8. You will need a V8 one.
Not all 96's were Grand Sports..there were many Coupes. Some of the Collectors Editions were M6 LT4's as well..
Old May 9, 2008 | 11:56 PM
LT1's Avatar
LT1
Oh ya thats right merv, the V6 and V8 have different bolt location on the bellhousing. i guess he will need new trans and drive shaft.
Old May 10, 2008 | 08:17 AM
the_merv's Avatar
Veteran: Air Force
Drive Shaft and Tranny Cross Member for it should be the same as well.
Old May 10, 2008 | 08:29 AM
Bad_tx_Z28's Avatar
why state are you in? I know in Texas that you cant put an older engine in a newer car because of all of the emmission BS....but you can put any engine in an older car and be good to go.
Old May 10, 2008 | 04:26 PM
LT1's Avatar
LT1
i thought V6's had two piece drive shaft.
Old May 10, 2008 | 05:38 PM
nighthawk15's Avatar
On early 4th gens (LT1s) they do for sure, but I believe at least some if not all of the later 4th gens, v6 included, got the one piece aluminum drive shaft. If it is a 2 piece though then yeah he needs another driveshaft.
Old May 10, 2008 | 09:52 PM
the_merv's Avatar
Veteran: Air Force
From what I have seen it was the early 3rd Gens..
