lt1 ls1 throttle
Old May 8, 2008 | 01:17 AM
1lt1wiz's Avatar
Exclamation lt1 ls1 throttle
can you use the ls1 throttle body on an lt1 and if so how
Old May 8, 2008 | 01:22 AM
porksoda's Avatar
Anything is possible with enough money! But as a bolt on no it will not work.
StealthFormula's Avatar
no they are completely different. The stock lt1 openings on the intake manifold are butterfly unlike the oval on the ls1's.
Old May 8, 2008 | 01:42 AM
Cross's Avatar
After looking at the IM's opening and thinking about the work I need to do to make it bigger for my 58mm Holley sitting here I start to wonder just how hard it would be to just make it oval.... probably require an aftermarket but there is certainly a lot of space there....
Nah I am wrong someone has probably already proven this.
Old May 8, 2008 | 07:31 AM
DAVE00's Avatar
Why not just port the opening and get the ASM monoblade TB?
Old May 8, 2008 | 07:34 AM
moserman's Avatar
those things are a pispot full of money
Old May 8, 2008 | 07:59 AM
DAVE00's Avatar
Not saying that I would ever get one as my BBK 58mm flows more than enough, but you're right they are a waste. The 58mm twin blades flow just as good and best to stick with it.
Old May 8, 2008 | 12:37 PM
BizZzatch350's Avatar
Moderator
The throttle body choices aren't the restriction on an LT1. A 58mm is more then enough on most any set up. I have seen the 58mm TBs make 500RWHP NA in pepe's car and over 900 in a blower/nitrous 383 LT4
Old May 8, 2008 | 07:03 PM
moserman's Avatar
yeah all of their stuff is overpriced and even tho the monoblade flows like 1300cfm or some **** like that, the intake has to be able to back it up and the LT1 intakes arent the best unless you cut them in half and port the **** out of them. i would love to convert to 90mm throttle body with the 90 degree elbow if anyone made them still
Old May 8, 2008 | 10:48 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
we make sheet metal elbows for both LT1, LS1, and most any aftermarket TB
Old May 8, 2008 | 11:35 PM
tylert14's Avatar
I'm going to be trying to fit a 90mm Infinity q45 monoblade on a lt1 intake, it's definately going to require some welding, grinding, drilling and taping and who knows what else. It only cost me $90 for the TB though...
