Changing to Auto? what the best setup
maybe turbo 400
maybe turbo 350
and what could i do with maybe a 4l60
thanks
We have converted a car or two from a six speed to a 4L60 and it is alot of work there is no question of that.
BUT it is a bolt in
but thanks for the help... also on the 4l60 would i have to change the tranny cross member and torque arm or do they use the same set up
thanks
The Cross Member bolts up into the same spot with the A4 and the M6.
I'm running a well built 4L60E in my setup, with Auburn Pro Series 7.5" Posi Differential, Motive 3.73's. and a Yank SS3600 Stall. I got it to cut 1.563 60ft's without any problems.
The auto will serve to help the 7.5" live too.
Trick is to find someone GOOD to either build the tranny or walk you through it. LOTS of shops claim to be capable but are not. This is a tranny where the assembler means more than the parts, a good assembler can make a lot of very stock parts last and most shops can make the latest in HD parts give up in a few hundred miles. I do not say this to discourage you just as a heads up. If there is a local shop that can do it and you can VERUFY that by talking to customers with the same tranny in a similar application that would be great.
FLT is a sponsor here listed on the right side of the screen, they are good, Rossler is good, ProBuilt Automatics is who I use and am happy and he is also happy to sell you parts and walk you through how to build it. These are about the only shops I am confortable recommending. As you research more also look for TIME in cars, lots of shops build trannies that hit hard and customers are happy for awhile, then in a year they break. Seen many companies come in become the new fad and 6 months to a year later it all comes crashing down because they never had a clue.
but i really appreciate the help..
thanks again
