A/C Question?
Also, when it is making the whinning noise, the air coming out is warm but once the noise stops it goes back to being cold again.
To answer other questions...I never gauged it. The hissing noise would only come from the low pressure port, no where else.
Is replacing the compressor (if thats the problem) a "do it yourself" kind of job because I know you have to have the a/c system drained before you work on it and then recharged afterwards? How much would a shop charge to fix this?
http://www.youtube.com/watch?v=psD8GQZz4gE
I started the car, and then 2 seconds in, I had my brother turn on the a/c. You can see the clutch engage on the far right of the screen, then my brother turned the a/c off right before the clip ends. It used to make this noise intermittently when I had the a/c on but now it makes it pretty much constantly with the a/c on. Thanks for your help!
