new 383 lt1
Old May 15, 2008 | 09:19 PM
fast414's Avatar
Default new 383 lt1
was thinking of a 383 stroker with a killer set of stock ported heads since they flow so well and intake and a nice custom cam with about 11.1 comp. thats the basic of what i would like to do to stay on a budget but still make some good power . i would be happy if it made 400 hp. it is my first motor build and am new to the lt1, is it a good direction?
Old May 15, 2008 | 09:37 PM
lt1noob's Avatar
if you only want 400hp dont bother building a stroker, this can be acheived with full boltons and a decent tune.
Old May 17, 2008 | 05:27 PM
fast414's Avatar
what kind of boltons do you suggest i am in the position to use the stock heads so what should i do to get the 400 hp
Old May 17, 2008 | 10:10 PM
lt1noob's Avatar
heads or stock ported heads, cam, tune, little things like cai, ported tb ect.
Old May 18, 2008 | 12:18 AM
BALLSS's Avatar
"if" you need a rebuild...buy a short block 383 and put your cam and Head choice on.
Golen makes a good short block. AI or LE make good head/cam packages.
If your bottom end is in good shape than just do a head/cam package
Old May 20, 2008 | 06:57 PM
fast414's Avatar
i have no choice to use the stock heads because im on a budget. so would a 383 or 350 with stock ported heads a nice cam with headers ported tb and a good tune with a couple other little things get me to the 400hp or more mark thanks
Old May 20, 2008 | 07:03 PM
jays97 t/a's Avatar
should be around 400 just depends on if u have 6speed or auto,im assuming u have a 6speed because u didnt mention a stall
BattleShip's Avatar
How much is budget? Why 400 hp? Do you mean 400 wheels or crank? Is it a daily driver? Gas mileage important? Will you do any of the work? Is engine running now? Whatg is its condition? Auto stick?
Old May 20, 2008 | 07:24 PM
Lt1junkie's Avatar
LLyod makes killer H/C packages
Old May 20, 2008 | 07:44 PM
Prototype007's Avatar
Spray will get you the numbers you want quickly as long as you used common sense and don't cram 300 hp shot jets on stock motor.
Old May 20, 2008 | 09:00 PM
C_Rules's Avatar
full boltons and call advanced induction for a h/c package.
Old May 20, 2008 | 09:35 PM
fast414's Avatar
its an auto and it a "weekend car" but i want it to be very street able and nos is not the direction am going . its fully stock right now and high 11's would make me very happy weather 400hp or not i just want to run high 11's thanks
Old May 20, 2008 | 09:39 PM
fast414's Avatar
its auto, budget means stock heads possible stock or rebuild short block... and as long as it will run around high 11's that would be awesome thanks
Old May 20, 2008 | 10:52 PM
BattleShip's Avatar
Your goals cannot be reached with stock heads on a budget IMO.
To get 11.99 with a 3700 pound car you need 434 RWHP. That will require a power adder such as NOS (ALOT), stall, tune, and gears. I do not see a budget car making it to the 11's and lasting.
To get in the 11's is a challenge to do it on a budget will take alot of talent and ability to do all your own work.
Old May 20, 2008 | 11:11 PM
SS MPSTR's Avatar
...just curious as to where you got your information.
Old May 21, 2008 | 12:01 AM
BattleShip's Avatar
I wrote a program to calculate et given weight and hp, or I can plug in a weight and time and get hp. There are many calculaors on line that will do it.
Few give same numbers because of assumptions but allow estimates. 3700 is probably on heavy side for weight but have to assume not everyone is 150 lbs.
Old May 21, 2008 | 12:15 AM
Dave J's Avatar
I think you program is off.Do you even enter D/A numbers?
numbers in sig were done in a 451 rwhp car@3450 lbs with a crappy 60ft and a +1800 D/A
Old May 21, 2008 | 10:18 AM
SS MPSTR's Avatar
I never trusted those online calculators, because they seem to ignore other factors that affect the ET, and power. Lots of Chevelle guys running deep into the 11's, with comparable weight and less rwhp. Not saying there isn't some credibility to the program for the purposes of discussion, but I think we can all agree they are not conclusive or absolute. Just my $0.02.
Old May 21, 2008 | 10:32 AM
BattleShip's Avatar
There are many possible reasons for the difference. The weight is off, the hp is off, or the et is wrong or other problems which would fill a page.
I think your dyno numbers are off. The ET’s are calculated for sea level. As I posted in the following thread
https://ls1tech.com/forums/showthrea...t=#post9399774
...if you want to know why there are differences in calculators here is a read
http://www.stealth316.com/2-calc-hp-et-mph.htm
I wrote a program to reflect the research done by the link above. My program uses their formula, I look forward to seeing something that disputes their findings with an equal quality of research and analyses.
Now for my questions to you
Do you believe your dyno can accurately measure your HP with a large stall and a transbrake?
I know many that have ~4000 stall that have LOW numbers on a dyno compared to their track tmes. That is not a problem with the calculator it is a problem with a dyno measuring some systems.
To verify my claim go to ANY track and there will be many who changed to a larger stall, went faster, but dyno'd lower. Does that mean the track timers were wrong? NO, that says the dyno is the problem.
Dynos showing low hp on a large stalled car is consistently reported on all sites, so why would your dyno be different?
Old May 21, 2008 | 11:41 AM
PNYKLR-TA's Avatar
I Also Agree That Is A Little Off, There Is A Guy Who Posted In My Cadillac Cam Thread That Has 375rwhp And Ran A 11.23. Let Me Find It And Ill Link It.
