My baby!
Like I said read the link do the calculation CHECK/VERIFY before you spend $$$. Just because I 'believe' should never cause you to spend your money until you verify and agree that it is wise!
The injectors should give you margin IMO, and 42 is LIKELY all you will need. The sight I linked is CONSERVATIVE if you check you will see they calculate for 80% duty cycle (almost all else will say 85%), but with boost you need some margin. Boost is about as addicting as CRACK!
To paraphrase
Boost, there is no substitute!
Remember the tune MUST ALWAYs match the injectors installed! Other changes usually are forgiving, and will live with old tune, injector changes aren't tolerant!
Instead invest in an Methanol injection system. They have one that is setup to inject based on MAF. This system is a great setup, and by adding a boost switch you can set it so that methanol begins injection at say 4 psi boost (point is adjusted with boost switch), and injects proportional to the air the engine is flowing.
The system cost ~$370 and ~$20 for the switch. It will not require a retune adds power by lowering intake air temp and increased octane (which will allow more timing and lower chamber temps), and provides margin. I have injectors laying around so easy for me to say change them but IF I didnt like you I would consider this instead.
To use the system you inject the methanol after your MAF (yours should already be on non pressure side) and after the supercharger. The Inlet air temp sensor (IAT) can be after the methanl injection.
http://www.labontemotorsports.com/st...ow/ISG-10.html
http://www.labontemotorsports.com/st...ow/VC-MAF.html
Good luck
And as a note a friend has a 8 psi Z06 and he has methanol, and professional tune (540 rwhp at dyno and similiar times at track), and he pulled the motor yesterday. He broke the skirts on 5 and 7. So an LS1 alone won't neccessarilly be the cure.
If you talk to LS1 they will say I am crazy that you can easilly run 8 psi NO problems on an LS1. Well the guy I am talking about put the BEST in his and he still lost the motor.
Any guesses which is more expen$ive to build an LT1 or LSX?
An LT1 with GOOD forged pistons, methanol, will hold ~500 RWHP. All you need over stock is pistons, o ring block (>~10 psi do it while apart), good springs, studs upper and lower. I would even recommend iron heads (cheap to put larger valves in), and lower CR to 8 - 8.5. I had that and ran 11 psi with 306 shifting HIGH RPM.
High RPM is NOT recommended my setup forced me to (4.11 gears) in a lite car with small tires (26") couldn't get next gear before over revving.
Your statement here shows your lack of knowledge. If you search this site or the net you will find tons of info on the subject, instead you chose your childish reply.
You are dangerous!
Not to me, because I can see you are looking to buy your first clue, I worry about someone who might think you know something.
Discussions are often heated and people disagree, but to only criticize without ever presenting alternant information is a sign of your lack of common sense and knowledge. I could careless what you think of me, but don't ruin the board for others who use it to get information and discuss problems with others.
You are the type person that causes many not to post. I want people to search his last 20 posts and see if there is ANYTHING worth keeping? Is this what you want? It is your site you decide.
I come here to share. If most of my time is spent pointing out the obvious I do not have fun and find it a chore and a waste of my free time.
Good luck
