Whats going on here?
Good luck to ya, Tom
Check EVERYTHING you have done. Headers and plug wires often like to meet and make for low power when the wire melts.
Edit
And the O2 extensions are a BAD idea.
Tuneup and ECM tune as mentioned is next on list once you verify nothing you did caused a problem
Good luck
Could it be my jerry rigged o2 extensions?
And then in my reply I say verify nothing you did caused a problem, and you aren't sure what I was referring to?
Edit: Never mind I just saw your avatar.
How cute - you're still struggling in high school I see. The OP mentioned they used jerry-rigged O2 extensions AND that they have
ordered "commercial grade" (I assume) O2 extensions, so you could have
been referring to "O2 extensions in general".
Gee look at the time...back to the post, sorry for the interruption. Check your work, it is never good to rig wires, it almost always ends badly. Verify the plug wires and anything you changed. EASY to swap plug wires so check and recheck.
It will be a small goof, a burnt plug wire, miswired plugs (swapped) or poor connection on 'rigged' extensions.
Good luck
If you used butt connectors for your home-made extension, that could EASILY be the problem, but if you soldered it then there may be something else causing the problems. There have been times when an O2 is good, but after removing and installing again, goes bad, so that might be what happened to you. If your car has been sitting awhile, say over the winter, it could easily be bad gas not letting you have the power you used to.
Would you prefer statements be left alone when they are wrong? The value of a board is it's accuracy, and some on this site struggle with accuracy.
EDIT: I FAILED to be clear T A&M was probably trying to clarify my answer. I should have been more specific. An answer that is not clear is NOT right.
So my bad on assuming T A&M had other than noble goals. If I was wrong on his intent I apologize. CLEAR answers should always be all our goals.
Clear answers ARE important and part of being correct! My reply lacked clarity!
Sorry for the HiJack!
