ALDL cable failure..HELP!
Old May 10, 2008 | 02:02 PM
flyinZ's Avatar
Default ALDL cable failure..HELP!
Im trying to figure out whether my cable is junk, or I dont have it hooked up in the port correctly, or my comp. port isn't setup correctly...Anybody have any tips? Im just trying to read the car, then upload a file...hopefully to datalog after that..Car is in sig.
Using an USB port cable, OBD1. I also downloaded a USB driver off of the Moates site, and the laptop recognizes that the USB cable is there, but it still says "No message sent-cable failure", whenever I try to read the PCM. Anybody?
Old May 10, 2008 | 05:27 PM
CamaroKid89RS's Avatar
Make sure you have the right COM port selected.
What program are you using to read the PCM, and to datalog it?
Old May 10, 2008 | 06:26 PM
97LT1's Avatar
Check your cigarette lighter fuse , as that is on the same circuit.
Old May 10, 2008 | 06:35 PM
buffman's Avatar
does the cable use the FTDI chipset? if not you're going to run into troubles. Make sure cable is assigned Comm port 1-5.
ALDL Test is a nice cable tester.
Old May 10, 2008 | 09:05 PM
flyinZ's Avatar
I've tried comm port 1, 3 and it didn't effect anything. I using a Flash program to read the car..
Buffman-I dont know for sure if it uses that chipset or not. I got this cable from an ALDL cable site a few years ago..so.
What is this "ALDL"test that you speak of? Where can I check that out at?
And I'll double check the cigarette lighter fuse as well..The lighter/socket has been removed for years, if that matters.
Old May 10, 2008 | 09:10 PM
buffman's Avatar
http://www.ttspowersystems.com/ALDL_cable.html
ALDL test will test from the computer to interface box connection
Old May 11, 2008 | 10:55 AM
flyinZ's Avatar
Thank you! I'll try that this afternoon and post back, what my results are.
Old May 12, 2008 | 01:07 AM
Dadic 78's Avatar
If you're stuck, call ALDL cable. That's what I did when I had problems with setting up my cable/software. They're good guys, and they'll walk you through step by step to get everything working. www.aldlcable.com
Old May 24, 2008 | 05:27 PM
flyinZ's Avatar
UPDATE: I tested the cable using that test from TTpowersystems, and it passed every test that I ran. I adjusted everything so it running off the same COM port,etc. Now the message Im getting is "No message from PCM", wtf? Did I do something in the wrong order? Do I have to start the car, to get streaming data in Freescan? I was just trying to read the pcm, and I got that message. Anybody?
Old May 24, 2008 | 07:36 PM
caldercay's Avatar
Which tuning and/or data logging software are you using?
Old May 24, 2008 | 07:40 PM
Dadic 78's Avatar
Which software program are you using? I'd suggest Datamaster. It's a free download, and you get 20 tries with it before you have to register and pay.
I had the same problem when using WinALDL. But when I switched to Datamaster, no issues.
Old May 25, 2008 | 11:00 AM
flyinZ's Avatar
It was a flash program I got from a non-sponsor tuner. I was just trying to read it first, then I got the "no response from PCM."...Going to try the datamaster this afternoon, and will post back, the new "message" i get,lol. thanks guys.
Old May 25, 2008 | 11:03 AM
lt170chevelle's Avatar
yeah and free scan has worked great for me and as it states...is free..also make sure your key is in the run position for a a few seconds before you try to read ..mine sometimes throws a fit if you try to read quickly after ignition is turned on.
Old May 25, 2008 | 11:31 AM
Dadic 78's Avatar
For LT1's datamaster can't be beat. Plus, you get 20 free recordings. Not a bad deal!
Old May 25, 2008 | 12:48 PM
flyinZ's Avatar
k..Tried Datamaster, just a little bit ago, nothin'. In the serial data acquisition box, or w/e..It says something like.."No connection to pcm" in a yellow box..no streaming data, nothing..wtf?
