Nitrous Help!
Old May 24, 2008 | 07:45 PM
WH97Z's Avatar
Default Nitrous Help!
I have 97 A4 Camaro with LTs and full exhaust. I'm running a NX Stage 1 EFI kit and the car seems to surge at higher rpms. I already run the NGk TR6 plugs gap is .045. blended my fuel and run lt4 knock sensor. I think it might need an upgraded coil or opti spark. Any ideas?
Old May 24, 2008 | 07:52 PM
robsquikz28's Avatar
is it while ur spraying or not
Old May 24, 2008 | 07:59 PM
WH97Z's Avatar
yes only on the bottle
Old May 24, 2008 | 09:12 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
how much are you spraying? my experience is that surging can be a good indicator that your jets need adjustment. is it a wet kit?
also do you have good bottle pressure?
walk yourself through all of the basic faq's, i am sure you will come up with the culprit
Old May 24, 2008 | 09:23 PM
1badzee's Avatar
fuel?
Old May 25, 2008 | 10:58 AM
lt170chevelle's Avatar
first off close that huge factory gap you are setting on those plugs should be no more than .35...also are you running wet or dry kit?
Old May 26, 2008 | 09:05 PM
armyracer11's Avatar
what kind of stall converter do you have, you could be blowing through it
Old May 27, 2008 | 10:24 AM
Formula383's Avatar
What size shot? You could be partially blowing out the spark depending on the size shot you're running. Close your gap a little like lt170chevelle suggested.
Old May 27, 2008 | 06:27 PM
z28camaross's Avatar
gap the tr6's at .35
Old May 28, 2008 | 10:28 PM
WH97Z's Avatar
Running a Nx wet kit. it will do it on a 100 shot and 150 shot.
Old May 28, 2008 | 10:30 PM
WH97Z's Avatar
Bottle pressure is at 1100psi.
Old May 28, 2008 | 10:33 PM
WH97Z's Avatar
plug gap is .45 will regap to .35 and see what happens.
Old May 29, 2008 | 11:32 AM
ToxicFormula's Avatar
Yea defeinetly regap your plugs. I think I run mine at like 36 or 38
Old May 29, 2008 | 11:00 PM
taner's Avatar
hmmm, i run my spray at 1000 psi, and it is 0.035 .... not .35, lol! sorry i couldn't resist
Old May 30, 2008 | 09:34 PM
WH97Z's Avatar
What N2O kit are you running taner?
