Corvette valve covers
Old May 28, 2008 | 02:01 PM
BizZzatch350's Avatar
Moderator
Default Corvette valve covers
Any thing in particular with using C4 LT1 Valve covers on a LT1 F-body? Seen it done a few times, but checking to see if there was any alternator clerance issues. All the 93 Trans Am magazine test cars had them, cant see any issues, but just double checking. Imagine the F-cars got stamped steel valve covers in a cost saving effort over the composite covers.
Old May 28, 2008 | 02:28 PM
Formula350's Avatar
People say you have to do one of two things, grind down the valve cover (hah fat chance I'd do that one) or grind down your alternator.
Now, what I plan to do if I ever manage to talk my friend out of his: Change the clock position on the alternator so it doesn't interfere with the covers! Then, still, if needed grind the alt.
Old May 28, 2008 | 02:43 PM
BALLSS's Avatar
Default lt4 covers
FWIW they fit my LT1...b-body though, with no clearance issues with 1:6 RR or alternator
Attached Thumbnails Corvette valve covers-rogmotor01.jpg   Corvette valve covers-dsc06287.jpg
Old May 28, 2008 | 08:11 PM
SnakeOiler's Avatar
They fit without issue.
Old May 28, 2008 | 08:18 PM
wrd1972's Avatar
I have composite LT1 covers on mine, but there is something to keep in mind. The LT1 composite covers have "drip tabs". These tabs hang down from the roof of the cover and MUST be cut off if being used with most roller rockers. The LT4 composite covers do not have the drip tabs and need no mods. Either will fit LT1 f-bodies just fine.
Old May 28, 2008 | 09:10 PM
Bad_tx_Z28's Avatar
I have always like the way those valve covers looked!
Old May 29, 2008 | 01:03 PM
Moderator
I have seen the drip tabs when I searched on Corvetteforums, seems like an easy fix with a dremel.
Old May 29, 2008 | 09:07 PM
wrd1972's Avatar
Takes 5 minutes with a Dremel cut off wheel.
Old May 29, 2008 | 10:01 PM
Moderator
Thats what I figured, its plastic after all, also you gotta clearance the stock Valve covers for bigger rockers, seems like the composites would be easier.
