Is this plug fouled?
Old May 29, 2008 | 04:46 PM
MTBSully's Avatar
Default Is this plug fouled?
Still trying to figure out why my car will stumble at low rpms and wont roast the tires in first gear, so while i was doing the plug wires i pulled out one of the plugs and it looks like this.
Is this fouled? There is a greyish buildup on the top and the base of the plug is all black. i have also heard bad things about Bosch plugs in lt1s. could this be the problem? Thanks guys
Old May 29, 2008 | 05:06 PM
BattleShip's Avatar
That plug is very black. The plug is fouled many reasons for it to stumble off idle, vaccuum leak, exhaust leak, o2's, plugs, plug wires, coil, cap, rotor, tune, etc, etc
I was given a set of those plugs and I thought they were WAY to expensive.
The ONLY plugs I use are TR55 or autolite 106 and that is from NA to 15 psi boost...Who tuned your car btw?
Old May 29, 2008 | 09:58 PM
MTBSully's Avatar
no tune yet
Old May 29, 2008 | 11:04 PM
BattleShip's Avatar
Check all that I mentioned. Get datamaster is the best investment. It requires a cable then you can collect 20 files.
Try it you will easilly find this problem with it.
Old May 29, 2008 | 11:07 PM
1996firebirdformula's Avatar
What kind of plug is it?
Old May 29, 2008 | 11:10 PM
1994Z28Lt1's Avatar
its a shitty bosch platinum +2 or something like that, the plugs are junk get yourself some AcDelcos, Autolites, NGK's, or just pretty much anything besides bosch plugs, you'll be thanking yourself later
Old May 30, 2008 | 08:16 AM
Formula350's Avatar
Well the plug DOES look black, but on the flip side that's a crappy pic :\ Use "macro" (flower pic sometimes) mode on your camera.
Right now, I'd say a little rich.
Old May 30, 2008 | 03:07 PM
MTBSully's Avatar
just installed my tr55s but i cross-threaded the #2 cylider so now i need to work that out.
Old May 30, 2008 | 03:17 PM
BattleShip's Avatar
Ouch
Proceed slowly...it is bad, but don't panick and make it worse.
