help?
Old May 30, 2008 | 03:48 PM
lil_lew52's Avatar
Question help?
every time i try to start my car it seems like it wants to start but i just dont start like i can hear it wanting to turn but its just dont, and it backfires through the throttle body sometimes, i think that its my opti but the backfiring is that normal?
Old May 30, 2008 | 03:50 PM
lil_lew52's Avatar
ima replace my opti tomarrow and i bought an acdelco, an a new ignition coil as well i tried switching the ignition coil already an still no luck just backfiring through the throttle body wen starting majority of the times
Old May 30, 2008 | 04:02 PM
kinglt-1's Avatar
Sounds like the opti is f*****!
Old May 30, 2008 | 04:15 PM
stfuad's Avatar
Did you check for fuel pressure before you decided it was the opti? Did you even test for spark? Not trying to be a dick but just replacing stuff in hopes that, that's the problem doesn't seem like that great an idea.
Old May 30, 2008 | 04:59 PM
lil_lew52's Avatar
yea i checked to see if i was getting a spark an no spark, that was the first thing that i did check, an how do i check the fuel pressure,
