Idle Problems
Old May 26, 2008 | 10:28 PM
SS#502's Avatar
Default Idle Problems
Has anyone else had problems with there car running fine at start-up and then once you get on the throttle the rpm's shoot up to about 3 grand and takes a couple of seconds to drops down and slows only to 1200 rpm?
Old May 27, 2008 | 12:07 AM
94CamaroZ28SS's Avatar
I think it may be your Thottle Position Sensor. Its $40 from Kragen or autozone.
Old May 27, 2008 | 08:36 AM
SS#502's Avatar
Well, I've pulled out the IAC and cleaned it good. Still no joy. Do you guys think it it could be the TPS? Tried doing research on here and found that most of the guys with problems are modded quite a bit.
Old May 27, 2008 | 08:40 AM
sweet-94z28's Avatar
You still have the stock TB, right? I would say TPS as well.
Old May 27, 2008 | 08:44 AM
Formula350's Avatar
$40 for the TPS O_O What happened to like $8!? Hell I'd just switch to the old Flat4 style then >_>
Anyways, idle should be 600-800rpms. So might want to check those hard plastic lines for a vacuum leak as well, along with everything else. PCV, IAC, IAT, TPS and maybe if the EGR is stuck open a bit (not sure if that'd cause it though)
Old May 27, 2008 | 08:45 AM
SS#502's Avatar
Sounds good. Yeah she still stock. I've only ported and polished the stock MAF and that was a while ago and it ran fine before. I've also checked for vacuum leaks and can't find any.
Old May 27, 2008 | 08:47 AM
SS#502's Avatar
I'll go out and check the PCV, I haven't pulled that in a while.
Old May 27, 2008 | 08:48 AM
SS#502's Avatar
Running to the store, I'll let you know what I find...
Old May 27, 2008 | 08:53 AM
EGR will make it die. Trust me, it makes it run really lean.
Old May 27, 2008 | 09:42 AM
Formula350's Avatar
Well, if I remember how carbs work, doesn't lean mix make the motor run at a bit higher RPM? So if it's only stuck slightly open, and not wide, it might affect it.
BTW, not sure if your motor has 2, and how much it matters, but my 93 had a PCV in the pass VC as well as the normal one in the intake Driver side.
Old May 28, 2008 | 08:05 PM
SS#502's Avatar
Well no joy on the TPS and PCV. Driving down the road and the car just cutoff like someone pulled the power from the ignition circuit. Car will start, but will only run for a little while before dying. Any ideas??????
Old May 28, 2008 | 10:02 PM
what about the fuel pump?
Old May 29, 2008 | 07:22 AM
Formula350's Avatar
HAH! Tighten your battery cables at the battery
Old May 29, 2008 | 10:33 PM
SS#502's Avatar
I have cleaned and tightened the cables and still the same thing.
Old May 30, 2008 | 08:17 AM
Formula350's Avatar
Damn :\ I've ran into your same problem before and it was my ground on the battery
Guess I'd check the cables at the starter too just to make sure, and the ground to the body.
Old May 30, 2008 | 05:11 PM
SS#502's Avatar
I'm away from home till Sunday, but when I get home I'll pull both battery cables and check the for breaks or corrosion. I guess the car being 11 years old could use some new cables anyways. Thanks for the insight, most of the time it's the simple things that make the biggest differences.
