What cam is in my car?
He will be lucky to accurately measure the lift near (+- .015") the actual.. That variance won't be close enough to determine the cam.
So bottom line there isn't anyway to determine the cam...
Although i still don't know why he says it pulls to 6600? A small cam would not pull that high. Did you get it on a dyno to see where the cam peaks at or did you just see where the rev limiter was set to? But as they said there is no way to know unless you get a grind number off the cam itself.
As mentioned, you need to either put it on a cam doctor, cross reference a grind number on the cam, or get the cam card from the guy who installed it.
