Can't decide on a cam, HELP (Yes I Read the Sticky)
I am perfectly happy not getting the full benefits from the CC306 as long as, even "short shifted" its outperforming the other off the shelf shelf cams.
Is it possible some of these myths came about because the inaccuracy of the stock tach? My tach sweeps just past 7k when in reality, it is at about 6500. The higher I rev the car, the farther the stock is off. At idle, its dead on and just gradually gets farther off as the Rs go up.
This argument needs to be put to rest. If you don't own a car with a cc306 then don't try to explain how it works and where it needs to be revved. Stealth, you're a really nice guy and have a ton of valuable knowledge but you're still wrong. As I already told you my car is only revving to 6400 max. This cam makes power to about 6100 so this is exactly where it needs to be as you already said yourself in the past. I'm not here to bash you but not everyone has the same goals and most people want to hear the truth about choices they have. I hope you don't take this wrong.
You like to throw out names to back what you have to say and in no way am I saying they're all wrong, but someone has to be wrong in this mix. My info came straight from Bryan Herter from PCM for less. He has dyno tuned hundreds of LT1 cars with the cc306 and it's hard to believe someone with his experience would be wrong. Most of the info you got was from people that want you to buy their product instead of the off the shelf alternative. Like I said this isn't to bash you but you personally haven't used this cam and I would like to believe someone that has tuned for it several times might know something about it.
I actually agree with you about how this cam looks on paper. But you know just as well as I do that it's not always the truth. I don't want to keep taking up this thread anymore. I feel bad for the guy who just had a question. My opinion from what I have and use says this is a good cam if you want to go big but if you don't want to spend money on all the supporting mods go smaller. There are other choices out there. Don't run away from any of them until you have all the facts though. Good luck.
as far as shelf cams, i would say the cc306 as well because even though you get the most out of it if you can spin a little higher that 6500, you can still make some good power all the way through the powerband with stock heads. so when you do put heads on there, it will really eat. but thats just mho and i'll admit im no big fan of the "baby cams" so that probably supports my bias, i also agree that a custom grind is gonna be your best bet.
Off the shelf I always recommend the Lingenfelter 211/219 which has .533" int and .560" exh lift with 1.6s and is on a 112lsa...next I like the CC503 also with 1.6s and after that I'd look custom...Either way I dont recommend over 220ish int duration and 230ish exh...just a personal preference...I've put many cars on the trailer with a lot more cam than I have...the big thing here is to match the cam to the head flow to the converter to the rear gear...
--Alan
--Alan
Wow... Looks like a lot was said while I was away... I talked to Jeff at thunder racing today, and he recommended for me the cc503 part number 07-503-8. He says the key to my goal is the torque, not peak hp and that this cam will probably be best suited for me. any thoughts???
