In need of ecm
Old Jun 2, 2008 | 06:27 PM
Smokeshow_2006's Avatar
Default In need of ecm
So, my local junkyards, even the one on national data bases cant find me a puter for my 93.
So.. It looks like I'll be spending more than I wanted to.
Any of you know where I can pick up a 93 puter reasonably cheap? Preferably, with a stock prom?
Old Jun 2, 2008 | 06:42 PM
BattleShip's Avatar
consider converting to 94/95 could be done fairly cheap. I have bought ecm and harnes for $125 b4
Old Jun 2, 2008 | 06:46 PM
fergymoto's Avatar
I sold one not to long ago. Watch eBay
Old Jun 2, 2008 | 06:50 PM
I'd like to keep my speed density setup. Can the 94/95 operate well without a MAF ( On stock tune temporarily)
Old Jun 2, 2008 | 06:51 PM
NorCalLt4's Avatar
i currently have a ecm and all the wiring harnesses, its for a 97 though
Old Jun 2, 2008 | 06:55 PM
BattleShip's Avatar
YES
It has sped density selection and can be programed with tunercat and collect data from datamaster so is an option. Many b bodys go to bone yards
Old Jun 2, 2008 | 06:57 PM
BattleShip's Avatar
if price is right could buy his harness..ecm is different for 96 97 obdii
Old Jun 2, 2008 | 07:03 PM
NorCalLt4's Avatar
i have the maf sensor too if he wanted to run it that way. It has all the wires and sensors you will need
Old Jun 2, 2008 | 07:16 PM
BattleShip's Avatar
I suggest you two discuss in private.
Personally the 94/95 is a nice setup especially of you need to fix yours. Mod is obviously factory and do't forget you sell what you don't use so price is not bad when it is all said and done.
BUT remember 97 ecm is different so you will ned 94/5 ecm
Old Jun 2, 2008 | 07:44 PM
BattleShip's Avatar
If he isn't interested in the maf pm me. I might be interested if price is right
Old Jun 2, 2008 | 08:40 PM
NorCalLt4's Avatar
alright sounds good
Old Jun 2, 2008 | 10:03 PM
Im not really looking to go the OBD2 route. But, What is involved in going with a 94/95 computer? They seem to be much more available.
Would it be as simple as getting a wireing harness from a 94/95(maybe a MAF too) and reinstalling?
Old Jun 2, 2008 | 10:08 PM
BattleShip's Avatar
the 97 wirig harness can be used...the ecm can't be
Old Jun 2, 2008 | 10:31 PM
Formula350's Avatar
Some people are becoming confused with terms. 92 and 93 are the ONLY LTx motors with an ECM. 94-97 are PCM since they also control the transmission, hence the P which is Powertrain. E is just Engine only.
I can't believe you can't find an ECM anywhere in the states. Did you try car-part.com?
As far as converting, I think 94 would bet he simplest to convert to w/o having to change a WHOLE bunch of other things. And as mentioned, yes a PCM can run in Speed Density mode, but aren't setup as well. After a tune, to make them intentionally run in SD mode, they work much better. The original SD mode is more of a fall-back if the MAF fails.
Old Jun 3, 2008 | 06:09 AM
I just checked out car-part.com. its a good resource, thanks for the link.
But... For the price of most of the ecm's on that site, I could go with a new item from Gmpartsdirect. $170+ core gets me a new ecm apparently. I just wanted to go the cheap route, and maybe faster than the estimated 2 weeks to get one.
Old Jun 3, 2008 | 01:50 PM
Formula350's Avatar
There's a "CORE" by me for $83, but who knows if it's a good or bad core heh. The rest are pretty damn expensive, I'm surprised.
Old Jun 3, 2008 | 03:34 PM
Yeah... I guess its because they were only produced 2 years they're rare, and therefor, valuable. I still have a couple options. Autozone, even though I dont like dealing with them, offer a lifetime warrenty on an ecm for $3, and some change. The good thing about them, is they quoted me a 2-3 day shipping time. Gmpartsdirect offers no warrenty, and will likely take 2-3weeks for $200 ish including shipping. Im still waiting to hear back from my local go to guy. he deals with a company in central massachusetts( im east of boston, yes.. east) thats got a very large yard...
So I dont know which way to go.. I dont mind spending the cash.. I just want my toy back on the road.. hah.. got to get some more milage on it... only been 8k this last year... hah.
Old Jun 3, 2008 | 03:42 PM
Formula350's Avatar
I'd go Autozone, depending on their ECM price, and then get the warranty on it. Not that ECMs go bad often, I've not have one go out on me. The nice bit about ECMs compared to PCMs though is the fact that if it does go bad, chances are the PROM will be OK and we can remove them
Old Jun 3, 2008 | 03:47 PM
BattleShip's Avatar
If he doesn't buy the harness write me...
A friend just asked me how much you want for the harness. The good news is he will convert a 93 TA with a burnt harness to 94/95 flash.
Then I can program the 93 TA computer to whatever program you want in it. I have a programmer for the 92/93 setup, so could be a double swap that works out.
The computers are often called ECM/PCM interchangeably. The important difference is the early speed density have a chip, the later has a Flash ROM. The flash rom can be reprogrammed in place the earlier have to have the rom removed to be reprogrammed, and the earlier do not control transmission.
Old Jun 3, 2008 | 03:52 PM
Formula350's Avatar
If you use a EEPROM with a remote chip holder and signal booster piggy back, along with a few other parts, you can program the ECMs in the car
Incoming PM though Battle.
