lt1 high idle problem
Old Jun 4, 2008 | 02:25 AM
stephen p's Avatar
Default lt1 high idle problem
so my '94 formula has a problem, when you crank it for the first time of the day, it idles around 1500, as expected, even after a good amount of driving it idles around 1100.. will not go any lower.. the throttle blades are completely closed.. any ideas?
Old Jun 4, 2008 | 07:01 AM
DAVE00's Avatar
Probably a bad IAT sensor or TPS sensor. Are you getting any codes (IE: SES Light)?
Old Jun 4, 2008 | 08:44 AM
great421's Avatar
For my 96 a bad Idle Air Control motor caused low idle speed; not saying it can't cause high, this was just MY vehicle.
I'd look for a vaccuum leak.
Old Jun 4, 2008 | 09:11 AM
moserman's Avatar
if you have an aftermarket throttle body you can adjust the idle screw or else just bend the tab back to your liking, but thats just a quick fix
Old Jun 4, 2008 | 06:03 PM
stephen p's Avatar
yeah. thats the thing, there is a gap between the adjustment screw, and the tab on the throttlebody.. no adjustment at all, and no codes, and no vacum leaks that i can find
Old Jun 4, 2008 | 09:38 PM
AlmostStockZ's Avatar
clean the t/b and iac passages
run the idle screw back out till it touches the arm. The car will set its own base idle 850-900 rpm untill it gets to the point where the blades are open enough that it has to completely close the iac.
I just went through this.
Old Jun 4, 2008 | 11:49 PM
formula1785's Avatar
i have the same problem...after warm up with ill go away for me..ive scaned for codes nothing comes up...only thing it could be is a vacc leak
Old Jun 5, 2008 | 01:15 AM
Formula350's Avatar
That's normal. "Cold" idle is mean to be high so it warms up, then when warm it drops down between 600-800. Mine's stock idle, which I kept when I tuned it, is 600. I've seen many people who say theirs idle around 800, hence the 600-800rpm range heh
Old Jun 5, 2008 | 08:26 PM
its not normal when its 1000 to 1200 tho... and up and down..
now its not doing it anymore
Old Jun 5, 2008 | 09:06 PM
SS#502's Avatar
I found a vacuum leak on mine right at the PCV Valve. I had the same problem and it was driving me nuts for a couple of days.
Old Jun 9, 2008 | 03:45 PM
Do You Have A (cai) In It?
Old Jun 9, 2008 | 04:04 PM
Formula350's Avatar
No, but solid 1000-1200 is normal though.
Could've been a stuck IAC that managed to break free. The up and down rpm could've been in and out movement since it couldn't open or close as far as it wanted. CD Drives are kinda like that on computers if they can't close or open all the way.
Old Aug 11, 2008 | 12:40 PM
lt1cst's Avatar
Hey I think im having the same issue with my LT1. I just put togather my 385 and when I start the motor the damn RPM's race up to about 2000k or so. sometimes higher. I have checked every possible vacuum leak, checked the TB blades, checked to make sure the gaskets were on, checked the EGR knock off plate in the back. Everything checks out. So im thinking as well it may be my IAC. So how do you check to see if your IAC is functioning properly? How do you clean it? Thanks
Chris
Old Aug 11, 2008 | 02:15 PM
Formula350's Avatar
Pull the IAC out and see if you can push or pull it. It'll be hard, but still push in and pull out.
As for cleaning, not rightly sure other than using carb spray.
Is the computer tuned for the new engine, if not that could be the problem.
Old Aug 11, 2008 | 03:11 PM
lt1cst's Avatar
Yeah this Computer is NOT tunned for this motor. I sold the other PCM that had the tune because I thought I was going CARB. But I changed my mind and stayed with the EFI. I picked this computer up from a donor camaro at a junk yard. Now I though stock PCM would be ok to run for now, The only thing I have is the bigger cubes and a cam. Everything else is stock.
Chris
I will check those things out.
Old Aug 11, 2008 | 08:25 PM
30th ponyslayer's Avatar
my 97 Z has idled at 1050 since it came off the showroom floor
Old Aug 12, 2008 | 04:55 PM
lt1cst's Avatar
UPdate!!
I pulled off the intake manifold to make sure the gaskets were on properly. They were. I resealed both ends of the intake manifolds with gasket sealer. Put everything back together, TB, all vacuum hoses ie master clyn hose. Checked PCV valve. Rechecked EGR port to make sure its blocked off. I started the car and the same result has happened. Car idles at 3K RPMS. So at this point my mind is pointing to a programming issue. Your thoughts would be great thanks
Chris
Old Aug 12, 2008 | 07:32 PM
97Z28LT1's Avatar
Could be the tuning. Did you try taking off the IAC valve and cleaning it? I ran into that on mine. Check all the vacuum hoses around the intake. Try spraying some carb cleaner around there and see if the idle starts to fluctuate. I would imagine its one of those 3. The good news is you're going to need a tune anyway and the other 2 options are fairly cheap fixes. Even if the IAC is actually bad, they're only $40. I'm pretty sure that's what I gave for mine.
Old Aug 12, 2008 | 09:29 PM
lt1cst's Avatar
I pulled out the IAC cleaned out the passage. It has dried up oil but nothing out of the ordinary. In looking at the IAC I was not able to move it back or forward. So it seemed fine to me. When I put the intake back on I made sure all passages were sealed. The only thing that I can think of is the PCM tunning. However, On a stock tune the motor should not act that way. At least I dont think.
Chris
thoughts?
Old May 16, 2014 | 03:45 PM
Scott Hadley's Avatar
1993 TA 5.7 vacuum line question. Should a vacuum line be attached to this? If so to where? I attached the blue nipple. ..didn't help....Its idling at 1,500 rpm can't figure out why???
https://www.facebook.com/photo.php?v=10202147187906781
