lt1 backfire problem need help!
Old Jun 6, 2008 | 06:54 PM
AAK z28's Avatar
Default lt1 backfire problem need help!
my car backfires at idle but wen i giv it gas it stops.. any one got any ideas?
i was thinking mab a rocker arm isnt adjusted right?
Old Jun 6, 2008 | 08:00 PM
robsquikz28's Avatar
did it happen after hotcam install or what?
Old Jun 6, 2008 | 08:05 PM
AAK z28's Avatar
ya after i put the cam in and adjusted the rockers...mab i didnt adjust 1 or a few right and the exhuast valve is open still while firing at idle?
Old Jun 7, 2008 | 01:07 AM
Untouchable9262's Avatar
Default yo
man i got the same problem , gaygays
Old Jun 10, 2008 | 01:35 AM
Default Could the Optispark be bad??
I changed my cap and rotor to a msd , but kept the origonally opti, my car seems to misefire alittle, and under load(about 2500rpm) theres a popping noise from my exhaust. Im currently running longtubes.
Old Jun 10, 2008 | 02:32 AM
carlos64030's Avatar
Just a long shot, but did you change out your knock module to an LT4 unit, or at least have the stock one desensitized?
