spark plugs for Trickflow Lt1 heads?
we just started my dads 383 for the first time with the new trickflows from TEA and could not find any TR6 Ngk's local so to start it we put some stock heat range Autolite 103's . My question is , does Trick flow have a special length plug or do they use typical LT1 spark plugs?
Also , if the 103's are the correct plug will they be ok with pump gas 11.4 /1 compression Or should we go with the Ngk tr6's?
I have a 396 with Trickflow heads from Lloyd Elliot. The ecu was tuned by Bryan Herter and they both said to go with Autolite 104 plugs. I am also running 12:1 compression.
