need help/ideas on building a procharged car for 15-17lbs
well I have a friend who wants to build an engine for procharger for 15-17lbs of boost, any ideas??
his car now is bone stock...
does he need to have a rearend also??
TIA....
15-17 psi is a LOT of boost for a motor with the displacement of an LT1 or LS1. I would recommend going 12 lbs at the highest, but if he's REALLY boost hungry, a fully forged low compression motor will handle 15 lbs.
- Tell your friend he's got to lower his compression to at most 9.5:1, first and foremost, if he's going for the big boost. A 10.5:1 compression motor should be alright with forged internals up to 12 psi, but anything above that will wear even forged internals quickly. Lower compression, although less powerful, is the way to go if you want your motor to last with that much boost.
- Forge everything, as Gangly said. Eagle is a great brand (what I use).
- Don't wait for the rear to go- replace it immediately with a 9" Ford or a 12-bolt GM. If the rear goes while he's running at the track, he'll most likely end up running into something hard and flat. The 10-bolt will definitely blow sooner or later. Also, an LT1/LS1 car would love some 3.73s too... 4.10s would be a bit of overkill with a blower.
- Is the car a T-56 or a 4L60/E? The 4L60E won't hold out for too long under that much torque, but a T-56 will probably fare better. Either way, tell your friend he'll be looking at a ruined trans within a year. His best bet after that would be a BEEFY 4-speed or 5-speed drag trans.
- SLICKS. Running that much power, he'll never get traction. We're talking 650+ horsepower here if he runs 15+ lbs.
Hope that helped... I'm still learning a lot of this boost stuff. Just tried to share my knowledge as best as I could. Tell your friend I said good luck!
well my friend doesn't want to go for stroker just a 347 or 250/360 for most. his car is 6 speed
can someone give me some details on the components??
thanks again guys....
well he's using a motor but may go for a crate since he's gonna order it from the States!
