Prom needed
Old Jun 12, 2008 | 05:11 PM
Smokeshow_2006's Avatar
Default Prom needed
Just one more step in diagnosing my issue, I want to replace my prom. Where could I find a NOS prom for my 93?
My local auto parts place couldnt find me one.
Old Jun 12, 2008 | 05:18 PM
Speed Density's Avatar
hashtagBMW
you just need a stock eprom?
Old Jun 12, 2008 | 06:16 PM
Yeah. My ecm/prom was/is under suspicion of failure. I replaced the ecm, which was a challenge enough finding one... But, reused my prom from the old computer, and the condition still exists.
Old Jun 12, 2008 | 08:10 PM
Formula350's Avatar
Well I have the BIN file if someone can burn it :\
Old Jun 14, 2008 | 06:14 PM
well I guess thats a no-go then eh?
Any other resources where I could look?
Old Jun 14, 2008 | 06:21 PM
hashtagBMW
www.speeddensity.org
moates.net, you could invest and get your own burner and sister chip for later down the road. And Craig Moates is a badass.
Tony.
Old Jun 14, 2008 | 10:59 PM
Formula350's Avatar
This is what I'm contemplating on buying. It'll burn the EEPROM too, so you don't need to light-erase the PROMs, instead it'll erase them for you. 28C256 I think is the EEPROM chip (Amtel).
http://cgi.ebay.com/Dual-Powered-Wil...QQcmdZViewItem
Then get the adapter board (sadly too expensive IMO) so you don't have to unsolder the original PROM, which I did. It's a hassle, and unless you're poor like me, I don't really recommend it. I did it with my TPI too, didn't solder it back in and had no problems, but this time it wouldn't make good enough connections so I had to solder the tuned prom in.
If you have any of the aftermarket big-name chips, they come with that adapter and you just need to pop out their PROM and slap yours in
Old Jun 15, 2008 | 09:34 PM
well, I just bought the generic jet stg 2 chip from summit this evening. Id still like to get into tuning my own chips though. Hopefully, this clears up my issue. If not, Im kinda lost...
Old Jun 15, 2008 | 11:21 PM
Formula350's Avatar
Even if you do decide to tune, that peice JET's chip comes on, is what you need to do your own. You burn a chip. pop theirs out, and use that housing it came in.
Old Jun 16, 2008 | 01:26 PM
hashtagBMW
Why would you not have just put the coin toward the moates stuff? Then you pay alvin@pcmforless $60 and he gives you .bins to burn that are for your setup
Tony.
Old Jun 16, 2008 | 06:49 PM
I didnt really research enough as far as the moates stuff goes. I just bought something generic, that is pre-programed to see if in fact my prom is failing. But, I probably will buy the moates stuff in the future
Old Jun 16, 2008 | 07:42 PM
Im checking out Moates as we speak. Im not all too confident when it comes to computer hardware issues. Im confused as to what I would need to self tune my 93.
Old Jun 16, 2008 | 08:12 PM
DADDY&GIRL93TA's Avatar
Tony.
What he said
Old Jun 17, 2008 | 05:57 PM
yeah.. so no change, although it does have a bit more response with the "jet" chip.
So.. I know an opti can cause a misfire, but... will the car idle to 1800rpm because of a bad opti as well? ( only have about 8,ooo miles on the msd unit.)
Old Jun 17, 2008 | 06:01 PM
hashtagBMW
If you need help buying/finding the stuff send me a PM and ill help ya out.
As far as your miss, how are your plugs & wires?
Old Jun 17, 2008 | 06:12 PM
Plugs are new ngk's, wires are msd's with 8000 miles, no burns, or freys anywhere.
When scanned, the car is putting up a repeating TPS sensor error, but replaced that early on when diagnosing, and still have the error. The car will run great for 17-20 minutes( timed) and is not dependent on temp, or wether or not it idled for that 20 minutes, or driving wot for 20 minutes. I wanted to completely replace the prom, but was led to believe that was the case with the jet chip, buts it only one of those memory adapters. I still want to completely replace the stock chip, unfortunatly, they're hard to find.
Old Jun 17, 2008 | 08:33 PM
Formula350's Avatar
It's not an updater. What the JET does is completely bypass the original, just the original piggybacks so you don't have to desolder it. All it uses from the original is the knock module (not replaceable with the LT4 one).
Check the TPS voltage. Should be .67. I've been running mine @ .54 w/o any problems, but plan to change it to .67 real soon.
Speed: Can you burn a prom for me, or possibly help with adjusting timing? I changed mine just slightly (timing) and I think it might have hurt more than helped. What I DID do, overall, helped a bunch though.
Old Jun 17, 2008 | 10:00 PM
hashtagBMW
PM me formula
Old Jun 18, 2008 | 03:50 PM
Well, I guess I'll be ordering a new cap and rotor, as its the only thing left to be replaced. Just another pita is all. Speed, You have a PM from me aswell.
