Msd 6al
Old Jun 19, 2008 | 01:42 PM
Ponch95's Avatar
Default Msd 6al
Just wondering does anyone use it? I know with a Turbo or SC application it is a must but what about straight motor? if so are you using a MSD Opti.
Old Jun 19, 2008 | 06:25 PM
grn95t/a's Avatar
yes on both, but do spary her alittle too.
Old Jun 19, 2008 | 06:32 PM
LT1's Avatar
LT1
ya MSD6AL will give you better spark, youll more notice it at higher RPM range, stronger spark.
BTW, if you plan to get one, i would recommend the harness for it, wont have to splice any wires.
im using it with stock opti
Old Jun 19, 2008 | 07:34 PM
96LT1355Z28's Avatar
Got one on mine, I didn't notice a difference in performance with it alone, but the rev limmiter is added security. Not to mention the 2 step, it's lots of fun!
Old Jun 20, 2008 | 01:57 AM
NorthernZ's Avatar
I have the addapter for the msd 6al, are any of you guys mounting them anywhere else besides the inerfender next to the fuel lines and fuse box
Old Jun 20, 2008 | 06:47 AM
bchncamaro's Avatar
I was gonna mount mine in the glove box, but the instructions were specific about not mounting it in a confined unvented area so I just put it on the fender.
Old Jun 20, 2008 | 08:44 PM
SS#502's Avatar
I have mine in the glovebox and drilled holes from the rightside of the glovebox and fed cooled air to it from the AC duct. Highly recommend the harness kit, I spliced mine just recently had problems with the box dropping the spark signal to the coil. Pretty frustrating, I had to disconnect the box in order for her to run so I could ship her to Hawaii.
Old Jun 21, 2008 | 07:52 AM
Mine's on the passenger floor, I didn't like it under the hood and didn't want to drill in the glove box.
Old Jun 21, 2008 | 04:24 PM
SnakeOiler's Avatar
I put mine on the passenger frame rail ( by the horns)
Old Jun 21, 2008 | 05:39 PM
383lt1impala's Avatar
yup buy the harness. i have the 6a and msd coil.
Old Jun 21, 2008 | 09:59 PM
93z28_6spd's Avatar
i have the harness and the coil with the stock opti...
i mounted mine under my CAI filter..like where the stock filter box would go.. .its out of the way and vented.. its great
Old Jun 22, 2008 | 08:21 AM
96capricemgr's Avatar
I did not use an MSD but I noticed no gain when I added an Accel 300+, like one poster said above I have kept it because I like having a spark based rev limiter on the car.
MSD opti is vastly LESS reliable than stock, though some who made the mistake of buying it will swear by it even as they tell you how to completely rebuild it before you can use it.
Old Jun 23, 2008 | 02:50 PM
slowpoke96z28's Avatar
i had the 6al and a nology coil, and i was all motor. i have always used and believed in factory AC Delco optisparks, and thats the whole unit, not just cap and rotor. get the vented style. if you got the nonvented now, you can get the vacuum harness, intake elbow, and fitting for the intake manifold. or get the harness, drill a hole in the hard rubber part of the elbow and tee into the fuel pressur regulator vacuum or AC vacuum.
Old Jun 23, 2008 | 03:32 PM
Ponch95's Avatar
Thanks guys for the info I went ahead and ordered the 6AL with the Harness and went with the stock Opti..(just in case) I already have the MSD coil so that wont change.
Old Jun 23, 2008 | 03:38 PM
Dragframe's Avatar
I have a mallory 685 and Lt1 harness for sale...
