Longtubes or Hurst + LCA relo. brackets?
Old Jun 23, 2008 | 08:32 AM
HoLLo's Avatar
Originally Posted by 97HawkLT1
When you do the longtubes, I would change out those Bosch Platinum +2 plugs for some NGK TR6s if you are still using the N20. TR5's if you aren't.
A good shifter should be the first mod for M6 cars as stated above. Makes a huge difference for fast shifting. Good luck with the car.
I haven't sprayed at all on the platinum plugs. And already have plans for some TR6s while doing headers. Thanks
I thought an "SLP shifter" was a Hurst though, is that correct?
Old Jun 23, 2008 | 03:23 PM
97HawkLT1's Avatar
They are two different brands but they are both short throw shifters, which is what you need. Everybody has an opinion as to which shifter brand is best. Any of the bigger name brand shifters should be at least decent quality. Here is a link to a few different brands that would work.
http://www.ws6project.com/user_stor/...ba9c2fd7d01e5b
Old Jun 23, 2008 | 05:38 PM
landstuhltaylor's Avatar
I hate still having my stock shifter, but I have gotten used to it. For the most part I can shift it pretty quickly. The only exception is the 2-3 shift where I really have to pay attention to what I'm doing. Personally, I would do the LTs first.
Old Jun 23, 2008 | 07:35 PM
tspence45's Avatar
If you do want a short shifter, in addition to LT's, I've got an ebay short shifter that I'll sell you for pretty darn cheap. I got it and the SLP short shifter at the same time, and decided to try the SLP first. Then, I decided I didn't want to go through the hassel of swapping it out again. Plus, the ebay short shifter takes a little bit bigger shift **** than the rest.
