View Poll Results: which is easier top or bottom
top
2
8.33%
bottom
22
91.67%
Voters: 24. You may not vote on this poll
LT's install, easier from top or bottom?
Old Jun 25, 2008 | 01:54 AM
BLK,97,T/A,M-6's Avatar
Default LT's install, easier from top or bottom?
Pretty straight foreward, but keep in mind I will have the tranny out to replace the clutch as well.
Old Jun 25, 2008 | 02:16 AM
96LT1355Z28's Avatar
I did mine from the bottom, it was easy. I have a tubular k-member and the car was on a rack. If you have a rack I'd say the bottom. If you'll be laying on your back it would probably be easier from the top. Having the tranny out will help!
Old Jun 25, 2008 | 02:18 AM
chavez885's Avatar
bottom
Old Jun 25, 2008 | 02:22 AM
ok.. 3 more questions
1) what size header bolts, 1" or 3/4"?
2) what length o2 extensions?
3) where can I get o2 sims?
Old Jun 25, 2008 | 03:25 AM
I think my bolts are 1"
My Pacesetters came with the driver side extension wires, I solidered em I didn't need one on the passenger side (I know I can't spell, it's early!)
I got my O2 sims from Summit, but when I had the PCM programmed I think they removed them, I havent tried to take em off to see if it does anything.
Old Jun 25, 2008 | 03:26 AM
luckyou03's Avatar
my pacesetters went in through the bottom
Old Jun 25, 2008 | 04:50 AM
TXFORMULA's Avatar
i think with a 97 you need the longer o2 sensor extensions
Old Jun 25, 2008 | 07:56 AM
RickyMartinZ28's Avatar
Bottom, and re-install the tranny first... You can't install the transmission with headers in the way...
-Rick
Old Jun 25, 2008 | 09:04 AM
tonskiguy's Avatar
Done it both ways, the good thing about the bottom is being able to install the headers and tranny on the engine first. I bought 1" header bolts and ended up shortening most of them.
Old Jun 25, 2008 | 09:32 AM
96SCTA's Avatar
For me the botom worked best, I had the motor fully assembled with tranny + k fram and headers and just drop the car onto it using a engine hoist to raise lower the front of the car. I also had my tires ands suspenisn on it so i just rolled it under the car. 4 k member bots and 4 tranny bolts and shes in. If u do it this way u can do it all ur self with no help.
Old Jun 25, 2008 | 02:16 PM
SS RRR's Avatar
Village Troll
Either/or will work. I've used 3/4" bolts since 2000.
The not sure on the length of the extendors. I think mine are 14", but can't remember. The sponsors on this site may know more about your two other questions.
Old Jun 25, 2008 | 04:16 PM
LTBANDIT's Avatar
i think your talking about the engine... he is just talking about headers...
Old Jun 25, 2008 | 04:20 PM
19mike84's Avatar
i did mine from the top in my driveway. i had to cut a little off the bell housing and take off my valve covers and spark plugs but it wasnt bad
ulakovic22's Avatar
Bottom was easier for me.
1" bolts
24" extensions
Can tune out the rears or Casper may still have some, not sure what happened with the whole lawsuit thing.
Old Jun 25, 2008 | 04:24 PM
litch2004's Avatar
i just finished putting in my hooker super comps and there was no way possible to put the in through the top. Mine went in only through the bottom. The only side i had a problem with was the drivers side because it hit on everything it could have hit.
Old Jun 25, 2008 | 04:28 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
From The Bum Area..................
Old Jun 25, 2008 | 05:09 PM
96LT1Camaro's Avatar
yo dont **** around putting it in through the top it is doable but hard. i put mine in through the top but it took so long and a couple windsheilds
Old Jun 25, 2008 | 05:15 PM
fbodyracing1's Avatar
I put the driver side from the bottom and the pasnger side frome the top and i had to pull each bolt out of the motor mount and jack the motor up and they just fit
Old Jun 25, 2008 | 10:24 PM
tonskiguy's Avatar
Oh, you're right, I'd have to say from the bottom.
Old Jun 26, 2008 | 01:05 AM
ok I ordered more stuff, please tell me if I missed anything.
1) 2 ac delco (pre cat) O2's
2) 24" extentions
3) new polly motor mounts
4) 2 odb2 O2 sims
5) ngk tr55's
6) I'll probably make my own block off's
7) stage 8 locking 3/4" bolts
Anything else?
