97 Formula/ Trans Am Ram air problems.....
Old Jun 25, 2008 | 05:59 PM
Blackbird97's Avatar
Default 97 Formula/ Trans Am Ram air problems.....
So I've been taking a close look at the factory ram air setup on my car. The piece of rubber that goes from the MAF to the throttle body doesn't seem to line up really well. It looks hella restrictive. Any body know of a fix for this? I'll post pics up if nobody knows what I'm talking about!
Old Jun 25, 2008 | 08:55 PM
rusnrno's Avatar
I replaced that rubber piece with a 3" rubber pipe connector purchased at Home Depot.
Old Jun 25, 2008 | 09:52 PM
TDavanzo's Avatar
Home Depot for the win
Old Jun 25, 2008 | 09:54 PM
HoLLo's Avatar
rusnrno. is that stock TB?
Old Jun 25, 2008 | 11:05 PM
Looks like i'll be making a trip to home depot. Thanks man! BTW Clean engine bay man!!
Old Jun 26, 2008 | 12:41 PM
Went to home depot, and got two different couplers. 3inch to 3inch, then 4inch reduced into 3inch. The reason for this is because I have and 52mm after market TB. I discovered that the 3 to 3 was too small for it and the 4 to 3 was too big..just by a little. So I just ordered a automotive type silicone reducer 3.5inch to 3inch. Hopefully it'll work. I should be getting it by tomorrow!
Old Jun 26, 2008 | 01:17 PM
TheDon619's Avatar
good, ya the stocker is pretty restrictive i bought a stock one when i went to ram air an di may do something like that, tho the space is very right and there not much tube showing. and hello there russ when did u move to this fourm also :p?
Old Jun 27, 2008 | 09:37 AM
ws6_z28's Avatar
You can get the 3"-3" coupler to fit aftermarket tb's...it just takes a little persuasion. Soaking it in hot water did the trick for me...I got it to fit my 58mm Holley.
