Ideas on cams?
Old Jul 4, 2008 | 07:22 PM
z28matt's Avatar
Default Ideas on cams?
I know their has probably been tons of these threads, but which cam should i go with? i have bolt ons (mods in my sig.) and i plan on keeping the stock heads and probably getting full valve terrain (roller rockers, ect.) which cam should i go with?
Old Jul 4, 2008 | 08:21 PM
19mike84's Avatar
lpe 211/219
Old Jul 4, 2008 | 08:46 PM
96lt1m6's Avatar
Originally Posted by 19mike84
lpe 211/219
i love that cam even though it is now dated!
that cam a set of 1.6s,tune and a 150hit make for a nice street player!
there are a few cams in the 226 range that are sweet! i am sure Dwayne(96capricemngr)will chime in with an offering.......
whatever you do don't over cam your car!
Old Jul 4, 2008 | 10:26 PM
Compstall's Avatar
IMO the primary concern first and foremost is, do you need to pass emissions, and, how much do you REALLY like to spend time under the hood fixing your car? If emissions aren't a concern, and you don't mind adjusting valves on a regular basis, go as big as possible without overwhelming the head configuration you plan to utilize.
Old Jul 4, 2008 | 11:50 PM
StealthFormula's Avatar
Gotta know a ton of info that you haven't stated yet to be able to give any kind of a worthy cam recommendation. Emissions? How high you willing to rev? Stall size/Gears? Daily Driver or Weekend Warrior? Smooth Idle or Choppy? Looking for top end power or low end torque? etc. etc. etc. Maybe read the sticky at the top of the forum that would get you on track.
Old Jul 5, 2008 | 08:06 AM
96capricemgr's Avatar
Our RPM limitations and the cam companies often way off RPM range recommendations are two BIG concerns.
Guys tell you to go "big as possible" but here in the real world 6500rpm is about all you want to put a stock shortblock through, and a cam mid 220s on the intake is usually going to need to see those rpms, will peak before that but you need to rev a few hundred rpms beyond peak.
