E.W.P And Heating up?
yes
At idle the electrics move more, but by cruise rpm depending on gears the CSR is already behind the mechanical flow wise.
Usually they are sufficient to keep a DD or drag car cool, but intercoolers or the like in front of the radiator would affect system performance more easily.
still have stock thermo stat as far as i know, i have never changed it but it may have been befor. the car some where along the line got a set of 3.73's so im not sure what els has been changed.
ill let the car get nice and hot and bleed it a few more times and see how it goes.
is there any thing i could do to get more air to the fans well driving, i dont currently have that leaf dam/ air gaurd thing under the car, could that make a big diff well driving?
I have the CSR here in AZ where the summer temps push around 125* degrees. Since I put the EWP on there, no problems to report at all.
I decided to check out the waterpump and steam tube that bolts to the back of the heads, well i took those bolts out behind the heads and the holes in them were filled with junk, like build up of what looked like casting sand. I drilled the holes out a bit larger and cleaned the junk out of them, then soaked the steam tube in a parts washer for a day and then blew it out and cleaned it up. Next i took the water pump apart and when i pulled the CSR pump out of the LT1 housing i noticed that the housing was pitted very bad and that same junk i saw in the steam tube bolts was in the bottom of the water pump housing. I also turned on the waterpump motor - come to find out the seal had gone bad and the motor had stopped working..
I purchased a new water pump housing, called CSR, and sent my CSR unit to them, they rebuilt it and sent it back within like 3 days, put everything together and a new 180 thermostat, spent an hour flushing the coolant system with the Prestone back flush kit, Prestone Radiator Cleaner & Flush, filled her back up with coolant and spent another hour making sure it wouldnt over heat.
after all that the car ran cooler than ever and still does. I have a 180 thermo in there and the coolant temp never gets above like 187- the needle just sits right above the 2nd mark on my coolant gauge in the dash..
Easy fix.
got the air dam on for a few drives and it helped. still air in the system but its ok becuse the head gaskets died on me after taking it to a local speed shop and having them over heat the car, warp the heads and drain the motor of all coolant and letting me drive it home with out telling me
so...ill give a 100% update next sumer when i get a fresh motor in her, untill then....she stays ncie and cold
....in the drive way on jack stands
