timing cover removal and help....?
Old Jul 8, 2008 | 09:09 AM
WHITEBOY_ZACH's Avatar
Default timing cover removal and help....?
ok yall. i did a search first but found nothing. i just tore into my block getting it ready for tha shop. i got all the rods and evrything out.
but i cant get the timing cover off of the crankshaft......does that hub press on the crank??
i can not get tha harmonic balancer hub to come off tha crank. it almost looks machined on there... is it??
and also i wasnt crazy i found a spun bearing and and 3 scores on tha crank where bearings still looked ok.
Old Jul 8, 2008 | 09:13 AM
METALBEAST's Avatar
You have to use a puller to get the crank hub off. You can rent one at Advance if you need one.
