Comp Cams 503 in 383
Old Jul 8, 2008 | 10:44 AM
LT1forever's Avatar
Default Comp Cams 503 in 383
Is anyone currently running this cam in their 383? My stock shortblock bit the dust here recently. But I plan on using the existing cam heads etc but wondered how well the Cam would do on a 383 setup.
Old Jul 8, 2008 | 12:51 PM
-PEPE-'s Avatar
that will be a very infant cam in a 383, I'm very rusty now, but the 503 was a tad smaller than the GM-847 or CC-306 which were also both baby cams for a small stroker like a 383.
Old Jul 8, 2008 | 03:23 PM
dre2013's Avatar
i would also say the 503 is too small...its quite a bit smaller than the cc306/gm847 cams. 224/230, 112 LSA, i believe lift is around .546 with 1.6's..not sure on the lift #'s though. Then again ive seen a few 383 setups that used hotcams(not sure why.). I would at least go with something in the mid 230 range, possibly a custom cam, or nice sized shelf cam (AI, LE, BRE, etc)
Old Jul 8, 2008 | 03:34 PM
BIG_T's Avatar
i would recommend a nice custom cam. the cc503 is good for stock heads or stock ported heads besides that i wouldnt use it.
Old Jul 8, 2008 | 03:55 PM
LT1forever's Avatar
Even as a Daily Driver? I'm not looking for anything radical. I just liked the 383 because its a 4 bolt.
Old Jul 8, 2008 | 05:05 PM
StealthFormula's Avatar
It would have amazing drivability in a 383. You would only have to rev it to like 6100 to get the most out of it. It is small for a 383 but would be great for DDing and would have tons of torque if thats what your looking for.
Old Jul 8, 2008 | 05:53 PM
fergymoto's Avatar
Like Stealth said it would have a great power range and decent economy for daily driving. It would be real fun to drive with the T56. I'd run it.
Old Jul 8, 2008 | 05:57 PM
dre2013's Avatar
if you want great driveability get a custom cam...they will be able to make something that will suit your needs perfectly. if you don't want to go that route, id say at least get the comp 230/236
Old Jul 9, 2008 | 10:16 AM
Z-RATED94's Avatar
If you already have the heads, I would go with something just a tad bigger. And what exactly do you mean by, you like the 383 because it's a 4 bolt?
Old Jul 9, 2008 | 10:59 AM
LT1forever's Avatar
I am worried about spinning a bearing. I was told the crank will flex less with a 4bolt as opposed to a 2bolt.
Old Jul 9, 2008 | 11:13 AM
connexion2005's Avatar
383's aren't 4 bolt by default. They are if you used a 4 bolt block to begin with. For example, I'm using my F-Body 4.000 Bore 2 Bolt Main black in my 383 build right now...
Corvette block is what you are using since they came with a 4 bolt main...
Old Jul 9, 2008 | 11:40 AM
th3brandon's Avatar
i belive iam going to go with the cc306 for my 383 build....like said before u wont have to rev it as high to get the most out of it in a 383....and it will have a good power range as well....just my 2 cents
Old Jul 9, 2008 | 11:47 AM
infinitebird's Avatar
There are MUCH better choices for a 383, even for a DD. Custom would be best of course.
Old Jul 9, 2008 | 12:15 PM
-PEPE-'s Avatar
infinite and a few others are dead-on..custom all the way to your specific build, cost is about the same and you'll get the DD WITH the added bonus of being fine tuned for your specific car. Allan Futral would be a good person to get in touch with for your grind. And 4-bolt 383's are built as such, not an automatic thing, although recommended.
Old Jul 9, 2008 | 01:48 PM
TWS's Avatar
TWS
I ran a CC503 in a 355 I had a few years back. It was fine in that motor and sounded great, but would be really small in a stroker.
I ran a CC306 in my 385 and it worked very well. 432/468 to the wheels through a 4L60E and a 12 bolt.
However, for my 396 I have gone with a custom Comp Cam that is bigger, much bigger, than a CC306.
Old Jul 9, 2008 | 02:03 PM
LT1forever's Avatar
theres about an 800 dollar difference between the 2 bolt and 4bolt 383. Would I just be better off to spend the money?
Old Jul 9, 2008 | 11:41 PM
69gto96z's Avatar
I would. If you are going to a 383, might as well do it right the first time around. Thats just personal opinion though.
