LT1 cam and engine upgrade advice...PLEASE HELP!
350 SB LT1 rebuilt and honed out...nothing drastic at all, just rebuilt
LT1 Alum. heads, street port and polish and a valve job but not oversized
Intake manifold ported to match heads and throttle body, and internals smoothed out
52mm Throttle body matched to intake manifold w/ an airfoil inside to stop the dead air
Smooth intake duct, High-Flow MAF, and SLP Cold Air Intake
Pacesetter long tube headers ported to match heads and rear O2 sensors deleted
Exhaust Y'd into single high flow CAT, to a flowmaster muffler, then 2 tailpipes
Underdrive Crank pulley and overdrive alternator pulley
EGR system deleted, AIR system deleted
160 degree thermostat, fans set to turn on at 180
AC Delco SP Wires, Spark Plugs, and front O2 sensors
Stage 3 clutch
Aluminum Flywheel
Complete computer tune to delete O2 sensors, EGR, AIR, re-set fan temp, etc etc etc.
NOW....my questions are this:
1. What cam would you recommend for a street car with a setup such as this? I am looking for something mild that isnt going to cost me a fortune and wont beef up my engine too much more, but will work nicely with what I am doing...I need a brand, lift/duration, etc recommendations if possible.
2. With all this done does my suspension need an upgrade? I am adding on a Hotchkis STB but do I need more or am I good? I was thinking SFC's and maybe a Torque Arm. I also have Polyurethane motor and tranny mounts.
3. How do you think my stock rear end is going to hold up to this??? and even my stock driveshaft?? Do I need to upgrady those as well?
4. If anyone has any other recommendations please feel free to let me know!! I could use the advice! THANKS!!!
karl
karl
A lil more - I'd go with the CC503
Either way you go, you should have a nice street/strip performer.
Your suspension/rear end should work fine, but can always benefit from an upgrade.
The underdrive pullies are a joke, you would be further ahead to buy a new damper that is underdrive, and with the raised idle of a aftermarket cam you wont need the OD alternator pulley.
Any idea what they did for pistons? Did they yse something with low tension rings like the STOCK LT1 has? If not they threw away power there. Did they go with lighter pistons so you can rev it up a bit more reliably? What sort of rpms are you looking to turn with it? Compression?
From what I am reading you should be able to hit the low to middle of your guessed range, with the right heads and cam the top end of the range would have been easy if the shortblock is any good.
For the rear to last, first thing it is avoid wheelhop, then no high rpm launches on slicks on a good surface.
What is a good lighter weight piston to use? Recommendations?
Same goes for the low tension rings...what is a good replacment for the stock without robbing me of power? I am not going for a strip car here, more street than strip, but I dont want to leave something out that could hurt me later. While I have it apart I better go ahead and cover all avenues.
