Valve springs
http://store.summitracing.com/partde...w=1&N=700+150+
You would need to pull the damper spring out of the 977's or have your valve stem guides machined down (common on aftermarket head work).
that 211 cam is great..
I believe the keepers are 7 degree so you can use your stock ones if they are. The Retainers might be different so get the right ones.
not a bad idea to replace valve stem seals while you are in there. FelPro or any "viton" rubber seal.
Lloyd
