Electric water pump
Old Jul 14, 2008 | 09:32 PM
alabamapimpin's Avatar
Default Electric water pump
well during my head and cam swap i would like to put an electirc water pump on since im down that far i was woundering whats some good brands and where to order them from all i have is jegs and summiy books thanx guys
Old Jul 14, 2008 | 09:36 PM
LS1 SPEED's Avatar
We can get you a Meziere or CSR pump if needed. I personally do not suggest an E pump unless it is more of a weekend car.
if you chose to go this route give us a call
take care
Old Jul 14, 2008 | 09:37 PM
1badzee's Avatar
I don't see a problem with running an e-pump on a daily. I am and so are a few of my friends, for years now with no problems.. Oh well. I'm sure there's some science behind it lol
Old Jul 14, 2008 | 09:53 PM
LS1 SPEED's Avatar
I had went through a couple a few years back on my 96 Z. There is far more reliability in a stock pump IMO over a stock pump.
it's just my opinion and could cost us a sale, but it's just the way I feel
BTW : I do have a CSR on my 97 now, but it is a weekend car if and when I have time to enjoy it.
Old Jul 14, 2008 | 10:00 PM
it is a weekend car and i will get up with u and order one by the end off the week thank you
Old Jul 14, 2008 | 11:00 PM
1badzee's Avatar
I agree on that.. Stock pumps are far more reliable. But I mean its a hit or miss. Like i said i havent had a problem for years now so i cant complain
Old Jul 14, 2008 | 11:34 PM
I8ASaleen's Avatar
Meh, get a wired, relayed warning system and you'll never have to worry about a failing e-wp again. I've got one with both a ground failure warning and a pump failure warning. It's real easy to pull out an electric pump and put in a new one once you have everything setup.
Old Jul 14, 2008 | 11:39 PM
transamws6_97's Avatar
I disagree. I went through two mechanical pumps in 2 years. So I switched to a Meziere EWP and hopefully this will last longer than stock ones
Old Jul 15, 2008 | 12:13 AM
NicksTAgt's Avatar
my first CSR lasted about 25k miles and a new one was only around 250 dollars, plus if you're doing a big cam it will help out with vaccum loss
Old Jul 15, 2008 | 09:25 AM
LS1 SPEED's Avatar
stock pumps last far beyond 60K miles in most cases...did you have cheap rebuilt units?
again please understand I'm not knocking the pumps and I have had them on both my cars, but if it was a DD I would not run one. This is just my opinion, so don't kill me
Old Jul 15, 2008 | 12:26 PM
BALLSS's Avatar
I put a meizere on 7 years ago after multiple "AC Delco" WP failures (they all leaked). The miezere is rated at 2500 hours and at a "average" speed of 35 MPH...that is 87,000 miles....which is way longer than any mechanical pump lasted for me.
I keep a spare in the trunk but have never needed it. Driving 5 hrs in 100+ heat to Vegas gatherings, etc., if the EL ever did puke at least i could swap in another on the side of the road in 10 minutes. having the "speed bleeder" with hose also helps in the system bleed as well for a "no spill" solution.
If the mechanical would have not become a chronic problem I would have stayed with it. While my care is no longer a DD I did do the swap when it was.
Old Jul 15, 2008 | 02:21 PM
LS1 SPEED's Avatar
wow! I have never seen stock pumps have so many issues.
good to hear a lot of you are having good long term luck with electric pumps
Old Jul 15, 2008 | 05:05 PM
LT1 TRANSAM's Avatar
LS1 SPEED how much are Meziere water pump i went on your website and it didnt say thx in advance
Old Jul 15, 2008 | 05:31 PM
LS1 SPEED's Avatar
STD $219
HD $236
free shipping in the continental United States
Old Jul 15, 2008 | 07:37 PM
BOLO's Avatar
I was going to swap over to an ewp when I did h/c in 2005, but why change something if it's not broken. Still running the same factory waterpump to this day, and it's 14 yrs old..knock on wood on this one...not a drip of coolant.
Old Jul 15, 2008 | 10:26 PM
aboatguy's Avatar
MEZ HD on my daily driver no issues, no warning system either but vettes have two coolant temp sensors (and in different locations too) I watch my guages so I don't worry about an idiot light for the pump.
Mike
Old Jul 15, 2008 | 11:34 PM
luckyou03's Avatar
I daily drive a e pump and it's been good for 15k miles so far. I would much rather replace an e pump than to pull all the water pump. I have a relay system on mine that some guy sold as a kit on the impala forums. It has a buzzer for a relay trip and a temp sensor in the passenger side head. works great.
Old Jul 15, 2008 | 11:38 PM
1badzee's Avatar
How do you hook up a light or buzzer to turn on when your pump fails?
Old Jul 16, 2008 | 08:59 AM
That is a sweet looking ride outta Memphis!!!!
Old Jul 16, 2008 | 09:13 AM
cgroh89's Avatar
Id be interested in the warning kit to. Right now I just have leds and a extra circuit with a diode so if one fails I can flip a switch and have a back up . But ive been trying to find a buzzer And I wish the damn Autometer warning lights werent so expensive btw
I have a Mez on my car and I havent had any problems except for the previous owners crappy wiring.Which is why I wired in a extra circuit with a switch ( never did make it up to speed inc for the open house. I was on the side of I355 then my car was stolen that night )
