lt1 stock redline
Old Jul 18, 2008 | 10:27 AM
kinglt-1's Avatar
When my m6 was stock it ran best shifting around 6000 acording to the tach, but we all know they read 100-200rpm high. On a scanner it was really turning 5750-5800. spinning a stock lt-1 higher than that is just more wear and tear on the motor!
Old Jul 18, 2008 | 10:41 AM
GIZMO's Avatar
Originally Posted by Purple95Z28
Stock Eliminator cars are not the norm. Nobody builds that style of motor/car unless, guess what, you run Stock Elminator.
Nothing was said about application in the original statement. The statement was about the limitations of stock heads and it was wrong.
Old Jul 18, 2008 | 10:47 AM
GIZMO's Avatar
For street/strip cars, ~6400 is the most you will get out of the stock heads... Untouched that is.
Another dumb statement. Setting limits on your combination is not the same as reaching the limits of your combination.
Old Jul 18, 2008 | 11:10 AM
LM97Z's Avatar
Forgot about the stock eliminator crowd.
Old Jul 22, 2008 | 01:05 PM
blackz93's Avatar
Originally Posted by Torkman15
I guess I'm curious as to the reason you would want to rev past the point the stock cam makes most torque???
Just remember this "Horsepower sells cars, torque wins races"
I seriously doubt you shift your car at peak torque!
Old Jul 22, 2008 | 01:18 PM
ss.slp.ls1's Avatar
Torque isn't everything. Most chevy motors make peak torque in the mid 4000's rpm and make peak horsepower in the 6000's rpm. If you shifted at peak torque, you'd be losing a lot of potential power.
Not convinced...shift your car at ~4500 rpm for every gear and see what happens.
Old Jul 22, 2008 | 09:21 PM
DADDY&GIRL93TA's Avatar
Theres alot to be learned there from those people if you drag race . Or just over all performance
Old Jul 23, 2008 | 12:22 AM
1994Z28Lt1's Avatar
Originally Posted by bobdec
Stock valve train numbers.. Did a couple of pulls a year ago prior to cam install, '94 A4 with CIA and CAT back only, original plugs, wires (72K miles), stock cam , springs, rockers, and exhaust manifold. Peak torque 278 at 4800 held flat till 5000 and then droped off slowly, peak HP 241 at 4000 flat to 4400 and then dropped off drastically to 190 at 5400. Have since added tune, new plugs, wires, a mild street cam, 1.6 RR's , springs and 3.42 rear. Waiting for headers and 2500 stall installation prior to next dyno pull. Hoping to get those crappy numbers up to something acceptable. IMO with an stock engine and valve train there is llittle value to up rev limiter beyond 5700.
that was one sick LT1 you had there with just CAI and Cat-back exhaust, i realize you are an auto so my numbers wont be quite like yours, but my car on the dyno with similar miles and mods pulled all the way about 5000 rpm for peak power and only dropped a couple HP's all the way up to 5700 rpm where i let off
peak torque was was hard to tell because it was pretty much level from 2000 rpm to 4500 RPM
Old Jul 23, 2008 | 12:04 PM
LM97Z's Avatar
I'll have to change my earlier statement i made, obviously it was a fuel issue, but after i installed a new pump & gears (4.11s), then i got to playing around with fuel pressure, i can now pull it to 6-6100 on the tach & its pulling there, i'm sure i can go higher, but don't want to push it, so i will say now its doable, 55-5600 (on the tach) now is just too low a shift point for the M6.
