LT1 Twin Turbo Kit?
Why are you jumping straight to TTs, a setup that is going to take a LOT of money and knowledge to keep it running right, when you only have a few minor boltons? Start with heads/cam, then build a shortblock, etc. Work your way up.
I kinda planned on doing it all at once. thinking about goin to the 383/heads/cam/TT. just getting an idea of where i could get a setup from. thanks for the help though
been did that
I've built a TT lt1 just using mild cam good heads .60 bore and forged everything else used the t3t4 twin turbo kit from eBay 1200 bucks have to be honest I was surprised on how good it performed 600 horses key not to over do the block with work when turbos work for u total build cost 5ooo rather build a regular 4 bolt main 350 vs lt1 block hate tht water pump takes away from a clean setup
2. You went 60 over and did boost?
D. Did you actually dyno 600 or are you guessing?
