LT1 stuck
Old Jul 22, 2008 | 03:30 PM
Chewie46's Avatar
Default LT1 stuck
I have a 95 LT1 that has been sitting for over a year. Today I tried to rotate the assembly and it will only rotate about 45 degrees. Someone said that the water pump could be stuck, any ideas?
Old Jul 22, 2008 | 03:34 PM
wrd1972's Avatar
Are you roating it over by hand? Dont see how the water pump can do that. Pull the plugs and try again if its out of the car.
Old Jul 22, 2008 | 05:48 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
+1 on pulling the plugs. That'll make it a ton easier to turn over by hand.
Old Jul 22, 2008 | 07:14 PM
Chewie46's Avatar
Default lt1 stuck
plugs are out, motor on stand, turning it over with a wrench on the balancer.
Old Jul 24, 2008 | 10:29 AM
blackz93's Avatar
Doesn't sound good!
Old Jul 24, 2008 | 03:45 PM
ss.slp.ls1's Avatar
Why was it sitting? Blown head gasket? Maybe rust & gunk in the cylinder walls holding you up. Seems like you are going go have to tear it down.
Old Jul 25, 2008 | 09:54 PM
MTBSully's Avatar
might be too obvious but i tried to rotate my crank a week ago and freaked out when it would only turn a few inches. Then i realized the car was in gear
