Clutter
Old Jul 23, 2008 | 12:42 PM
Skidd's Avatar
Default Clutter
What can be removed from the car? Im tired of them mess of lines wires, ect around the intake.
Old Jul 23, 2008 | 01:16 PM
ss.slp.ls1's Avatar
Since you have no sig and you gave zero information, I'm going to assume you have an Fbody.
You can remove the EGR valve and the EGR tube and block them off using block off plates.
You can remove the air pump and off of the tubing and block/cap everything off with block off plates.
All related vacuum lines can be removed and the ports can be vacuum capped off.
Be careful not to mix up AIR & EGR stuff with EVAP stuff, this should no be removed.
Note: You will see zero performance gains, this is purely a cosmetic mod.
Old Jul 23, 2008 | 01:20 PM
1SlowFormula's Avatar
you can remove anything you want, it is your car, at least that is how I look at it...
Then again if you have to deal with inspection and emmisions then you may want to keep a few things on there...
Old Jul 23, 2008 | 10:29 PM
Skidd's Avatar
No inspection or emissions, just looking to remove all unessecary stuff. Wasnt looking for a performance gain just trying to clean it up.
Old Jul 24, 2008 | 01:45 AM
zlover129's Avatar
depends on how much time and effort you want to put into it ...
Old Jul 24, 2008 | 02:39 AM
94LT1Bird's Avatar
for a closer look
Old Jul 24, 2008 | 06:36 AM
then go ahead and pull whatever you can to make it look decent and still run right...
That's what I did. It started off slowly and I pulled the AIR, then later when I did headers I pulled the EGR, at some point I pulled the Cruise control and traction control, then I moved to a low mount alt and pulled the wires to all other accessories. At some point when I pull the motor I will rerun everything to look a little neater, but right now it took a lot of that crap out of the way and I will be pulling the ABS and power brakes soon to get even more clutter out of there...
Old Jul 25, 2008 | 12:13 PM
Skidd's Avatar
Air and egr stuff is off so now to the other side. Im going to remove the canister ect but what is this other one for?
Old Jul 25, 2008 | 12:37 PM
ss.slp.ls1's Avatar
Those are the EVAP solenoid and purge valve. I wouldn't mess with them.
Old Jul 25, 2008 | 02:10 PM
Skidd's Avatar
Guess Ill replace the 2 rotted lines.
