30# Injectors
Old Jul 24, 2008 | 01:06 AM
tspence45's Avatar
Default 30# Injectors
So, I'm assuming that since I'm basically stock, with just a few bolt-ons, the stock injectors are probably just fine. But, I plan on camming the car this winter. Probably going with a CC306 and hopefully mild head port job. Would I need bigger injectors? I found some red top 30# injectors for a really good price and was thinking about buying them. Would I benefit from them now even, or would it really matter?
Old Jul 24, 2008 | 03:25 AM
NorCalLt4's Avatar
well i put a cam in my lt4 camaro and now i need injectors real bad. i would buy the injectors now and install them when u do the cam.
Old Jul 24, 2008 | 05:16 AM
96capricemgr's Avatar
The 30lbs injectors are a good choice but the 306 cam is a poor one.
Old Jul 24, 2008 | 07:17 AM
DAVE00's Avatar
Good idea to go ahead and get em' as it can't hurt, just make sure you tune your car for them and if they are SVO's then tune it higher than the 30# more like 32-34 as SVO's are rated at a lower fuel pressure on the ford cars as we run higher 43 PSI.
