weird problem? any help?
Old Jul 24, 2008 | 04:17 PM
bricez28's Avatar
Default weird problem? any help?
my can everyonce in a while when at a low rpm, it'll sound like one cylinder cuts out? or its not getting enought fuel or somehting. but when i gun it up to like 5000rpm it kicks back in. and when its running bad it makes a tick sound from the exhaust? anyone know? i was thinkoing maybe a fuel filter? or a air filter? anyone? no cats on the car.
Old Jul 24, 2008 | 04:35 PM
bricez28's Avatar
Old Jul 24, 2008 | 04:42 PM
96silverram's Avatar
Strong Island,
Your probably going to need a little more info to get some help, fairly vague. I suggest you start with the obvious, pull the plug on that cylinder (inspect), check plug wire (contact, shape & condition), plug wire connection at the opti, do you have a scan tool or a guage like the aeroforce interceptor ? If so, it will read any misfires in cylinders or codes from the PCM.
Old Jul 24, 2008 | 04:46 PM
bricez28's Avatar
its not any known cylendere its just what it sounds like. im clueless as the the source of this problem. im gunna have to scan it... can a fuel filter or an aiorfilter make somehting like this happen?
