stock lt1 nitrus
Old Jul 26, 2008 | 03:39 PM
1lt1wiz's Avatar
Default stock lt1 nitrus
looking at getting nitrous 145.000 miles with mods in sig what shot can be ran safe
Old Jul 26, 2008 | 03:59 PM
I8ASaleen's Avatar
A 100-shot, but I don't know if I'd say it's "safe" to run N2O on a 145k mile longblock...
Old Jul 26, 2008 | 05:45 PM
LM97Z's Avatar
If you know the history on it & its not been too abused with good oil pressure, 100 shot should be no problem, you'll just need a window switch to control ON & OFF rpms for the juice, make sure your fuel pressure it up to par, an adj. regulator never hurts, i have my pressure (new walbro 255) up to 54 psi WOT (off reg. vacuum) & this ol'e LT1 loves it, i'm in the process of getting a base NX kit from NitroDave, i'm sitting at 158K.
Old Jul 27, 2008 | 03:48 PM
rdlt1's Avatar
157 and running a ZEX system, go for it just don't run it hard all the time. Any of them can pop at anytime.Enjoy the ride...
Old Jul 28, 2008 | 04:48 PM
n2ocamaro's Avatar
Whatever you run here are the must haves. Nitrous filter, window switch, fuel pressure saftey switch, TPS or WOT switch, bottle heater. I highly recommend a wideband 02 sensor and a lean shutdown switch as well. If you don't get the last 2 things at least put it on the dyno the verify AFR
Old Jul 29, 2008 | 08:47 PM
Prototype007's Avatar
100 wet shot and you should be safe.
